4.0 Crank?
Old Aug 10, 2008 | 07:02 PM
Grn4fbody's Avatar
Default 4.0 Crank?
Is there any Gen3/4 engines that come with a 4.0 stroke crank? That would fit into an LS6 block?
Old Aug 10, 2008 | 08:16 PM
98mysticZ's Avatar
i belive the 427 crank is... BUT the reluctor ring is diff.. but not 100% sure sorry man
Old Aug 10, 2008 | 08:17 PM
Grn4fbody's Avatar
Can you change the ring? I cant even find a place to sell a LS7 Crank
Old Aug 12, 2008 | 10:39 PM
silverbandit0996's Avatar
haha your local GM stealership.
Old Aug 12, 2008 | 10:58 PM
Grn4fbody's Avatar
Bet I could get a aftermarket one cheaper is that was the case LOL
Old Aug 13, 2008 | 01:10 AM
99blancoSS's Avatar
http://www.sdparts.com/product/12568...rankshaft.aspx
Eagel or Scat crank is cheaper, its close to the same price as my Callies compstar
Old Aug 13, 2008 | 09:20 AM
Sales2@Texas-speed's Avatar
LS1Tech Premium Sponsor
Also keep in mind the LS7 crank is set up for GM'd dry-sump combo. You would have to machine the crank to make it work and change the reluctor wheel like mentioned above. Unless you've got a HECK OF A DEAL on the LS7 crank, it will not be worth your effort. We offer a variety of crankshafts that will suite your needs of power handling and your budget.
Let us know if we can help
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old Aug 13, 2008 | 06:10 PM
98mysticZ's Avatar
i forgot about the dry sump
