What brand of dual spring is this? (help identify)
Old Aug 24, 2008 | 11:53 PM
Mike96z's Avatar
Default What brand of dual spring is this? (help identify)
What Valve Springs are these? (Help Identify)
I bought some heads, they have these dual gold springs on them, they look to be either Patriot Performance Gold or PRC springs. They are made by the same company I know but how am I to distinguish the two sets? Is there something in them that have a diff color? Im going to pull a spring and snap some pics, maybe I can find a local performance parts store who can match em. Any help is appreciated.
I found this info:
5. Patriot Gold Duals: See Crane and 921’s. The PP Golds come on all PP heads. PP are the only genIII spring setup to use the super 7 10* locks.
O.D 1.29
135lbs @ 1.800
385lbs open
coil bind @ 1.08
.650 lift
My Personal Indepedently tested PP golds:
seat: 143 lbs @ 1.800
open: 363 @ 1.200
coil bind: 1.060
Clearance: .140
spring rate: 367
6. PRC Dual Spring Kit: Kit comes with Dual springs, tit. retainers (using stock locks), seats, valve stem seals. good for up to .660 lift
seat : 140lbs
open: 390lbs
install : 1.800
coil bind: 1.07
1.290 O.D.
max lift : .660
matl : super pure chrome silicone
- PRC Platinum springs:
seat: 145# @ 1.7850"
open: 395# @ ?
PP, PRC, TEA, and all other "Gold" springs are all made from the same manufacture; Associated Springs. The differences are in the retainers and seat locators.
Here are pics of mine:
Here are manufacturer pics:
Patriot Gold
PRC
Patriot Extreme Dual Springs (silver inner spring/mine are gold)
So I see there is a diff in the locks, what will be the diff in the 10 degree versus stock valve locks?
Thanks
Mike
Old Aug 25, 2008 | 12:19 AM
35th SS's Avatar
I would say Patriot golds.
Old Aug 25, 2008 | 03:56 AM
94'BLKBRD's Avatar
i think you answered your own question....lol
Old Aug 25, 2008 | 08:31 AM
Yeahdoug's Avatar
If my memory is correct, the retainers look like ferrea.
Old Aug 25, 2008 | 10:20 AM
Mike96z's Avatar
well the guy who sold them to me said they were PRC but he said someone told him that, as far as I know, Patriots Gold and PRC are the same company, so maybe the same spring from both company's, just a diff name? I just need to know because 1 was broken and I need to order a new spring.
Thanks for any help.
Old Aug 25, 2008 | 10:24 AM
Mike96z's Avatar
seems hard to identify, unless there is some kind of number on the retainer or sumtin i can look for?
Old Aug 25, 2008 | 10:41 AM
Mike96z's Avatar
Unless as stated the two brands are exactly the same, i found a guy here with a great pic, look exactly like mine, the only difference is that my inner spring is also gold, not silver and he says:
Link:
http://forums.nicoclub.com/zerothrea...rint&id=250906
Old Aug 25, 2008 | 10:47 AM
Mike96z's Avatar
well i see their normal spring is gold inner and the extreme has silver inner
Old Aug 25, 2008 | 11:11 AM
Mike96z's Avatar
O.D 1.29
135lbs @ 1.800
385lbs open
coil bind @ 1.08
.650 lift
open: 363 @ 1.200
coil bind: 1.060
Clearance: .140
spring rate: 367
seat : 140lbs
open: 390lbs
install : 1.800
coil bind: 1.07
1.290 O.D.
max lift : .660
open: 395# @ ?
found this info but dont know how i can use it to determine my springs.
Old Aug 25, 2008 | 01:02 PM
5.3LJimmy's Avatar
Yours are definitely PRC. The Patriots use the larger super 7 locks and PRC re-uses the stockers. If you look at your pic versus the pic in post# 7 you can see the difference in retainer diameter.
Old Aug 25, 2008 | 01:09 PM
Mike96z's Avatar
yea his locks do look bigger than mine, didnt think the other locks were bigger, just thought they were stronger.
Old Aug 25, 2008 | 01:12 PM
Mike96z's Avatar
Thanks! I think you are correct, they are much larger than PRC and as seen here they have kinda goldish color to them.
Old Aug 25, 2008 | 01:13 PM
99mongooSS's Avatar
Im pretty shure they are prc's they look identical to mine
nevermind the pic above looks diff.
Old Aug 25, 2008 | 01:15 PM
Mike96z's Avatar
these are mine
Old Aug 25, 2008 | 01:17 PM
99mongooSS's Avatar
yeah those above look like prc springs.
Old Aug 26, 2008 | 07:06 AM
TVWilkes's Avatar
They are 100% PRC springs and retainers.
Old Aug 26, 2008 | 10:34 AM
Mike96z's Avatar
Thanks, does anyone know the installed height of PRC's vs Stock?
