Oil pressure drops to zero at idle.
Old Aug 25, 2008 | 09:16 AM
Marc '99T/A's Avatar
Unhappy Oil pressure drops to zero at idle.
Never had this problem before, but I was on my way to Houston last night when my oil pressure started to drop to zero anytime I got off the interstate and the engine would idle. Any ideas other than the obvious (oil pump possibly going bad)? This is in my Jeep, FYI, but I figured that it would be the same concept as in the LS1. Thanks for the help, as I'm supposed to be making a 15 hour drive to Virginia in a few days.
Old Aug 25, 2008 | 09:29 AM
AFASTYZFR1's Avatar
oil sender could be dying
Old Aug 25, 2008 | 09:32 AM
SOMbitch's Avatar
Does the valvetrain get noisy like it is starved for oil? If not I would look at the sending unit then gage.
bjamick's Avatar
is it spiking, or just steadily falling when you come to idle? If its spiking then its prob your sender, if its steadily falling its prob your oil pump.
Old Aug 25, 2008 | 09:40 AM
The valvetrain is not noisy at all, and it is a slow, steady drop; there are no spikes in the pressure either up or down.
Old Aug 25, 2008 | 09:42 AM
IronOutlaw's Avatar
Pull the oil pan and see if the pickup fell off.
Old Aug 25, 2008 | 09:45 AM
But if the pickup somehow is gone, wouldn't there not be any pressure at all?
Old Aug 25, 2008 | 09:47 AM
99NMB's Avatar
First off i would try hooking up a manual gauge and getting a actual reading, the factory style sender units are known for showing false readings.
Old Aug 25, 2008 | 09:53 AM
Is that something I could "rent" from AutoZone, and where would I hook that gauge up at?
Old Aug 25, 2008 | 09:56 AM
bjamick's Avatar
Theres a place that you can tap in right above the oil filter.
Old Aug 25, 2008 | 10:01 AM
mvvette97's Avatar
Just get a new sender and I bet all will be fine.
Old Aug 25, 2008 | 10:11 AM
Thanks for the help so far. I'm going to definately check the pressure with another gauge to bypass the sending unit. But let me run this idea by you guys: What if there was crap built up on the pick up screen. At idle, the pump might not have enough suction to overcome the buildup, but as the rpm's go up and the pump pulls harder, it has enough suction to get the oil past any buildup......? Just a thought.
I'm definately hoping its the sending unit. I'll be in Houston until tomorrow. If it looks like I can wait until I get home, then I'll fix it then.
Old Aug 25, 2008 | 10:19 AM
mvvette97's Avatar
driving down the road where is the needle on the gauge? Or if the gauge reads pounds how much does it have? Not likely the screen is covered with sludge unless the engine has been abused as far as oil changes. I have only seen one engine in my life that has had the screen plugged with crap and that was an old engine from the 70s
Old Aug 25, 2008 | 11:33 AM
Ok, I just drove it around for a while and now everything's fine....WTF? The gauge reads right in the middle (can't remember what the psi is) I'm just going to keep an eye on it, and if it starts acting up again, at least I have some ideas on where to start. Thanks guys.
-Marc
