HELP!! THINK I JUST SCREWED UP MY MOTOR!!
Old 02-10-2003, 12:59 AM
BRIAN98Z28's Avatar
Default HELP!! THINK I JUST SCREWED UP MY MOTOR!!
I just raced my buddy in his really quick mustang like 7 times in a row, all high speed races (145+)On the last race I thought I was in drive and when it was time to shift to OD, i shifted, but hit nuetral because i had mistakenly already been in OD, and smacked the rev-limiter a few times. After I slowed back down I realized i had a REAL loud tapping noise coming from the motor. Almost sounded like a really loud lifter tick. The car drives and idles fine, no smoke, no leakin oil or coolant. Just the noise....what do you guys think I could have done???? I hope its nothing major. Also, do you think hooking it up to Auto-tap could help diagnose it? My buddy has it and I thought we would hook it up and see whats going on. Any help would be GREATLY appreciated.
Brian
Old 02-10-2003, 01:03 AM
Jabroni's Avatar
Default Re: HELP!! THINK I JUST SCREWED UP MY MOTOR!!
Sounds like you may have bent a pushrod or two. Unfortunately, a common occurrance in LS1's. The upside is that it is not too hard to check them if you are remotely handy with tools.
Old 02-10-2003, 01:10 AM
BRIAN98Z28's Avatar
the first thing I thought of was pushrods. Especially in the early years of the LS1's I remember people were bending pushrods a lot. I'll have to check them out tomorrow after I get out of class. Does anyone know how much hardened pushrods cost? I am doing a cam soon so I was going to upgrade to hardened ones probably from pace parts or scoggin dickey.
brian
Old 02-10-2003, 01:19 AM
I8COBRA's Avatar
Around $100
Old 02-10-2003, 01:21 AM
Gustin's Avatar
might want to check the rockers as well. One might of come apart. If you drain you oil and find little needle bearings on the dran plug then a rocker came apart.
Good luck,
Sean
Old 02-10-2003, 01:39 AM
LSX Mechanic
Damian's Avatar
More than likely you have just bent some pushrods. It's a cheap easy fix, takes about an hour tops. Pull the valvecovers and check before you freak out, it's probably something minor..
Josh
Old 02-10-2003, 01:51 AM
BRIAN98Z28's Avatar
thanx guys, thats what i figureit is....lets hope so.
brian
Old 02-10-2003, 07:56 AM
BRIAN98Z28's Avatar
great....buddy of mine said he thinks it might be a spun rod bearing....which means new motor.
brian
Old 02-10-2003, 09:22 AM
ibjamin's Avatar
Why would a pushrod bend by hitting the rev limiter? This was an automatic tranny. He didn't miss shift on a stick (like hitting 2nd when he wanted 4th) and mechanically over rev the engine.
You should still check the pushrods but it could be something worse. <img border="0" title="" alt="[Frown]" src="gr_sad.gif" />
George
Old 02-10-2003, 09:27 AM
mikemodano9c's Avatar
the cheapest and lowest cost thing it might be is a check vavle...
it makes a loud ticking noise when one goes...
Old 02-10-2003, 09:28 AM
BRIAN98Z28's Avatar
ibjamin....i did mechanically over-rev the engine. Re-read my post. I was manually shifting the tranny, was in overdrive when i thought i was in drive..accidentally shifted it into nuetral while I had the pedal to the floor, and thats when i bounced off the rev-limter. Smacking the rev limter is an easy way to bend pushrods.
brian
Old 02-10-2003, 10:19 AM
UnbelievabLS1's Avatar
Maybe you just thought you were manually shifting it, but the computer was still shifting it, not you.....hence the designation 4L60E! <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" /> And I seriously doubt you've converted it to manual valve body. <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
It's probably just pushrods like everyone else has mentioned. Easy fix...ask me how I know!! lol <img border="0" title="" alt="[Eek!]" src="gr_eek2.gif" /> <img border="0" title="" alt="[Razz]" src="gr_images/icons/tongue.gif" />
Old 02-10-2003, 10:45 AM
Ed Blown Vert's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by BRIAN98Z28:
<strong> ibjamin....i did mechanically over-rev the engine. Re-read my post. I was manually shifting the tranny, was in overdrive when i thought i was in drive..accidentally shifted it into nuetral while I had the pedal to the floor, and thats when i bounced off the rev-limter. Smacking the rev limter is an easy way to bend pushrods.
brian </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I don't think by hitting the rev limiter you are mechanically over revving it. All you are doing it cutting fuel.
Its when you have a M6 and shift into a lower gear and you spin the engine way past the rev limiter.
<small>[ February 10, 2003, 10:47 AM: Message edited by: Ed LS1 Vert ]</small>
Old 02-10-2003, 11:16 AM
DanZ28's Avatar
Brian, I think your friend might be right, sorry to say. I to doubt it's a bent pushrod from banging off the rev limiter, but definately rule out any and all the easy stuff first. In my own experience of banging off a raised rev limiter to long, resulted in a spun rod bearing for me. Good luck!
Dan
Old 02-10-2003, 11:24 AM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,160 Likes on 754 Posts
Probably bent pushrods.
Manually shifting a stock 4L60E is a pretty bad idea. I could manually shift my FLP trans but it was built to accomodate that.
Old 02-10-2003, 11:38 AM
DanZ28's Avatar
Well, try using the screw driver held to your ear trick. If it's a pushrod, the sound should be easily detectable through the valve cover. If it sounds like it's more from the bottom or the middle of the engine, you have another problem.
Dan
Old 02-10-2003, 01:05 PM
Bink's Avatar
Wouldn't a main be more of a "clunk" than a "Tic or a "clack". Damn, this sounds like a frickin barnyard. But seriously wouldn't it sound more like a thud or clunk??
Old 02-10-2003, 06:01 PM
DanZ28's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by binksz06:
<strong> Wouldn't a main be more of a "clunk" than a "Tic or a "clack". Damn, this sounds like a frickin barnyard. But seriously wouldn't it sound more like a thud or clunk?? </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Where referring to the rod bearing not the main bearing. My rod sounded more like a tap than anything else, not really like the typical knock you would expect to hear...
Dan
Old 02-10-2003, 07:00 PM
LS1Tech Co-Founder
I have a friend who did the same thing and he bent two pushrods.
Manually shifting will burn out the trans do some research it might seem fun but ultimately the trans will go out really fast.
Old 02-10-2003, 07:30 PM
horist's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by MUSTANG HAT'R:
<strong> the rev limiter only works when the cars in drive.
floor it in neutral if you dont beleive me I bet it goes <img border="0" alt="[bomb]" title="" src="graemlins/gr_bomb.gif" /> </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I'm not sure if I've ever tried it in neutral, but i've done it before revving in park, it would bounce off the limiter... i'm pretty sure neutral is the same way
