???agressive Stock Cam Sound???
Old 09-02-2008, 08:54 PM
nemss1's Avatar
Question ???agressive Stock Cam Sound???
does an 01-02 F-body cam sound more agressive than a 98-00 cam since it has smaller LSA?
which stock LS cam sounds meanest? 2000 vette cam? 15.5 LSA?
Summerwolf's Avatar
The Z06 vettes sound the meanest cause they have the most agressive cam
Old 09-02-2008, 08:57 PM
nemss1's Avatar
i know LS6 sounds more agressive but which cam out of the different cars and years of the LS1's sound meanest?
Old 09-02-2008, 09:09 PM
Summerwolf's Avatar
2004 GTO- It has the best cam out of the LS1 cars
but then again the GTO used an LS6 block with a different cam ls6 intake and 241's with true dual exhaust...so it definitely sounded different then a camaro or firebird
Old 09-02-2008, 09:13 PM
nemss1's Avatar
what is the LSA on a GTO LS1 cam?
Old 09-02-2008, 09:17 PM
Summerwolf's Avatar
Intake lift... (inches)
.324 - LS6 (2002-2004)
.306 - LS6 (2001)
.292 - GTO
.274 - Vette LS1
.268 - Trans Am
Exhaust Lift.... (inches)
.322 - LS6 (2002-2004)
.306 - LS6 (2001)
.292 - GTO
.281 - Vette LS1
.274 - Trans Am
Trying to find out LSA and everything
Old 09-02-2008, 09:18 PM
INMY01TA's Avatar
98 f body had the bigger cam.
Old 09-02-2008, 09:25 PM
Summerwolf's Avatar
out of fbodies- yes....but the vettes and GTO's had better cams than the fbodies
Old 09-02-2008, 09:56 PM
nemss1's Avatar
the smaller the LSA, the more agressive sounding right?
Old 09-02-2008, 09:57 PM
Summerwolf's Avatar
typically yes, but that is not everything
Old 09-02-2008, 10:00 PM
snake charmer's Avatar
yeah a smaller lsa sounds more choopy and agressive . the 98-99 cam is a bit different than the 01-02 . there a lot of folks that run the ls6 cam from the 02+ z06 in turbo and some na setups .
Old 09-02-2008, 10:02 PM
nemss1's Avatar
ya i kno, but the 00 cam is a big cam but its to smooth sounding for me lol
mchdg86's Avatar
If you are thinking about swtiching your mac for one of these meaner sounding stock LS1 or 6 cams dont wast your time. You wont nottice a sound difference and you will only notice a slight but not worth while gain from the LS6 cam. Just get a 224 cam on a 112 LSA instead. You will still have great daily drivability and notice a lot bigger of a power gain and agreesive sound. Just try to get it to idle around 700 or so with an open cut out and you will have a nice little lope to it.
Old 09-02-2008, 10:07 PM
nemss1's Avatar
i want a smooth but lopey sound. not rough and choppy
Old 09-02-2008, 10:11 PM
INMY01TA's Avatar
No. The more overlap the more aggressive the sound.
Old 09-02-2008, 10:15 PM
mchdg86's Avatar
You will never get that kind of sound out of a stock cam. You cant even lower the idle enough to get any kind of lope out of a stock cam. Hell a stock A4 f-body idles at 500 rpms. Just get a 224 cam on a 112 LSA and it will do exactly what you want.
Old 09-02-2008, 10:17 PM
nemss1's Avatar
what stock LS1 cam has the most overlap? vette cam or f-body?
Old 09-02-2008, 10:23 PM
IronOutlaw's Avatar
Just get a hotcam.
Old 09-02-2008, 10:26 PM
mchdg86's Avatar
The 02+ LS6 cam has the most overlap. But you would still have to change springs for it if that is what you are trying to avoid.
Old 09-02-2008, 10:31 PM
nemss1's Avatar
what cam has the most overlap out of the LS1? (incuding Y-body vettes)
