Cam Question
Old Sep 4, 2008 | 07:16 AM
badazz99ta's Avatar
Default Cam Question
im getting my engine rebuilt. it goes in the shop today. im doin some last minute questioning on my choice of a t-rex cam cuz ive been doing a lot of research on here. first of all, here is what im doin:
PRC Stage 1 LS6 Heads With PRC Dual Springs (Already Bought)
Cam
LS7 Lifters
LS2 Lifter Trays
LS6 Oil Pump
LS2 Timing Chain
Diamond/Mahle Pistons
ARP Rod Bolts
i think thats about it. i may be missing some minor stuff. my other mods are in my sig. reason for build is a spun bearing, so we r turning the crank, and if we cant then i will get a new one. my car is my dd, but in a couple weeks i will have a company truck. so i will drive that everyday. so this car will turn into my weekend car. i have family in texas, arkansas, and oklahoma, so i will be taking it on trips. if i ever leave this job the car will again be my dd. so i want a cam that i wont have problems with on the street, but i want to make some big power. i do want to go with the t-rex cam, but would that be the "BEST" cam for my setup and how i want to use it. i do plan to go the strip, but i will use the car more on the street. thanks. Dan
Old Sep 4, 2008 | 07:37 AM
teke184's Avatar
you could probably put together a better setup with better heads and a smaller cam.
it will make similar power high, probably more power low, and be more street friendly.
but i think its too late now
Old Sep 4, 2008 | 08:56 AM
badazz99ta's Avatar
^^^lol. yeah its for sure too late on the heads, but i still got time to choose a cam.
Old Sep 4, 2008 | 10:27 AM
teke184's Avatar
go smaller...i say low 33x would do nicely.
depending on the PTV clearance....maybe the TSP torquer 3, or the futral FM14HL
off hand i don't know how those heads would fair with .64x lift
Old Sep 4, 2008 | 11:05 AM
ZL1Killa's Avatar
would you want to talk to Patrick G about a cam? he is really good, and I'm impressed with mine
Old Sep 4, 2008 | 11:47 AM
badazz99ta's Avatar
yeah, i pm'ed him the other day. he said the trex would be fine for a weekend car. he said find someone to put a mad driveability tune on it though. chuck at hpe is the one tuning. ive heard hes good. i shouldnt have to worry about ptv with the new pistons. thats the only reason im gettin new ones.
Old Sep 4, 2008 | 11:57 AM
venom ws7's Avatar
T-rex and PRC heads will make a great setup.
Get those heads milled for more comresstion and the car will fly.
Oh you need a set of gears with tRex
Old Sep 4, 2008 | 01:15 PM
badazz99ta's Avatar
^^^about the milling. what do they need to be milled to. and what exactly is getting milled. i keep hearing this, but dont really know what exactly. and i have 4:10s in my m6 for gears.
Old Sep 4, 2008 | 01:56 PM
MM98's Avatar
"Milling", is having the deck of the heads shaved down.. This will raise your compression which in turn gives you a lil more power, specially down low where you'll need it with a cam that size.. You just need to make sure of your PTV clearance when having your heads milled with that cam..
Old Sep 4, 2008 | 02:32 PM
F8L_LS1's Avatar
MM98 summed it up.
to help with your milling quest, i would suggest getting the heads milled to 62cc's. with cometic .040 head gaskets that will give you 11:1 compression. great quench and you can run 91 all day.
Old Sep 4, 2008 | 02:42 PM
badazz99ta's Avatar
well i will talk to bryan at pavlock perfomance, hes the one doin the build. ill see if he could do that for me. thanks for the help so far guys.
