5.3L head question
Old Sep 6, 2008 | 05:02 PM
BluLS1's Avatar
Default 5.3L head question
okay so i'm looking at getting some 5.3 heads to put on my 98 ls1 block and was wondering what the best ones to get are and what do i need to do to them thats worth the money.
i'm waiting on getting a cam until last because i'm gonna get a custom grind for it.
Old Sep 6, 2008 | 05:24 PM
LS1Z28-00's Avatar
ive got the stage 2.5 5.3s from texas speed, they work well and you can get them used easily for 1k.
Old Sep 7, 2008 | 02:34 AM
BluLS1's Avatar
well i can get stock ones for around 100 bucks, i was just wanting to know what the main things to do to them that will help.
i'm def gonna get em ported and polished for sure.
i was just wondering if some of the newer ones might be a litte better than the older ones or visa versa
Old Sep 7, 2008 | 04:44 PM
Samba242's Avatar
Mine came from TEA. They were like $1600 with no core. Brand new castings used. Very pleased with them. Are you planning to port/polish yourself, or have it done?
Old Sep 7, 2008 | 07:53 PM
BluLS1's Avatar
i'm good with a machinist so i'll probably have him do it. i would buy some heads ready to go but i don't have the money like that to throw at them.
what consists of a 1.5 stage heads?
Old Sep 8, 2008 | 05:19 AM
SOMbitch's Avatar
You need to put 2.02/1.57 valves in them.
Old Sep 8, 2008 | 05:06 PM
racer77ss's Avatar
Casting Number 241
Head: 1997+ LS1 5.7 Litre Passenger Car
Material: Aluminimum
Part Number:
12559806 (1997-98) Chambers = 69cc
12559853 (1999-00)
12564241 (2001-03)
Combustion Chamber Volume: 66.67cc
Compression Ratio: 10.1:1
Intake Port Volume: 200cc
Exhaust Port Volume: 70cc
Intake Valve Diameter: 2.00 inches
Exhaust Valve Diameter: 1.55 inches
Casting Number 243
Head: 2001 LS6 5.7 Litre Passenger Car
Part Number:
12564243
Combustion Chamber Volume: 64.45cc
Compression Ratio: 10.5:1
Intake Port Volume: 210cc
Exhaust Port Volume: 75cc
Casting Number 706 + 862
Head: 1999+ LR4 4.8 Litre Truck
1999+ LM4 /LM7 5.3 Litre Truck
Part Number:
12559852
12561706
Combustion Chamber Volume: 61.15cc
Compression Ratio: 9.5:1
Intake Valve Diameter: 1.89 inches
Casting Number 373
Head: 1999-2000 LQ4 6.0 Litre Truck
Material: Cast Iron
Part Number:
12561873
Combustion Chamber Volume: 71.06cc
Casting Number 317
Head: 2001+ LQ4 6.0 Litre Truck
Part Number:
12572035
Compression Ratio: 10:1
the 706 and 862 head have a smaller itv 1.89 and you would need at least 2.00 or 2.02 to take atvantage of the higher compresion of 11.8:1 on a ls1
Old Sep 9, 2008 | 02:41 AM
Samba242's Avatar
Pretty much the same as a Stage 2, but with stock 1.55 exhaust valves to keep the cost down.
