Ported ls1 heads or ls6 heads?
Although if it was a budget and you had to pick between Ported LS1 heads & LS6 cam vs. Unported LS6 heads and nice 224/228 cam, I would pick the LS6 heads & cam combo.
Ya' just have to talk to the right folks about getting the parts and work done.
and remember guys,it's not just about X amount of cfm a port flows,it's about the quality of airflow thru the port that makes power..don't think just because a port flows 300cfm it's going rock..
you can do things to increase cfm on a flowbench that will,in a running engine,actually hurt power..just something to think about..
If you have a stack of bills in your hands then ETP's 225's can't be beat, but they require some blue printing due to angle configuration. Trick Flows and AFR's are not far behind at all, AFR's being a true bolt on.
To be honest about it, the wise thing to do would be to have your heads and cam properly matched if you really want to play in the big game. For that purpose a call to Ed Curtis at Flowtech Induction is the way to go.
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
