6.0 CI Head Flow Numbers
Old Sep 7, 2003 | 04:53 PM
stealth's Avatar
Default 6.0 CI Head Flow Numbers
What are the best flow numbers that anyone has seen through a set of 6.0 CI heads?
Old Sep 7, 2003 | 07:53 PM
stealth's Avatar
Default Re: 6.0 CI Head Flow Numbers
Am I to believe that no one has flowed 6.0L heads?
Old Sep 7, 2003 | 07:57 PM
XLR8NSS's Avatar
Adkoonerstrator
This question is probably better suited to the internal engine section even though they're truck heads.
I'll move a copy of it over there.
BigTex's Avatar
You looking for stock head flow numbers or ported? Your best bet is in the internal engine section.
I used a set of ARE stage 2 6Ls that flowed 295 intake and 220 exhaust I think.
Old Sep 7, 2003 | 08:54 PM
VINCE's Avatar
Shorty Director
Thunder Racing flowed 6.0L heads awhile ago.. You can do a search..
Old Sep 7, 2003 | 10:19 PM
y2khawk's Avatar
Mine were flowed at 295 intake and 245 exhasut, 2.020" 1.60" valves
they are at the shop getting fitted for big springs and 2.055 intake valves. Will be re-flowed after that is done.
Old Sep 7, 2003 | 11:21 PM
Scott Turvey's Avatar
I have a set flowed at 320 & 242 with 2.08 and 1.60's.
Old Sep 8, 2003 | 09:37 AM
Vents's Avatar
AAP is "supposedly" pushing out a 330+ CFM head. i dont see why this wouldnt be possible, but why not start looking C5R? compression concerns?
Old Sep 8, 2003 | 09:47 AM
Nasty N8's Avatar
We can get 330+ for big inch motors. C5R is just way to large for a street car, you loose all volocity and lowend.
Nate
Old Sep 8, 2003 | 09:49 AM
Vents's Avatar
ooh, look at the top end though nate
Old Sep 8, 2003 | 11:30 AM
I should have mentioned this is for a blown application. I'm doing a manifold for a Roots-type blower (6-71/8-71)
Old Sep 8, 2003 | 09:58 PM
99 Black Bird T/A's Avatar
Might want to ask TEA about their 6.0 new SAM/Judson spec 6.0 heads. I would expect with SAM/Judson involved the heads would be top notch.
Old Sep 8, 2003 | 10:03 PM
TVWilkes's Avatar
I have a 6.0L head on a 4.06 bore it will flow 322 with 2.08 valve.On a 3.905 bore with a 2.02 valve it will flow 302.
Old Oct 11, 2003 | 08:23 AM
stealth's Avatar
Who are AAP and TEA? I would like to contact them.
Old Oct 11, 2003 | 09:06 AM
Time2Kill's Avatar
MASS seller approved
TEA = www.totalengineairflow.com
Old Oct 11, 2003 | 11:39 AM
Linear Velocity's Avatar
AAP is Andys Auto Perfromance, they were a sponsor until the owner Mark Avila was killed in a car accident . I have 5.7 AAP heads that flow 337 intake @ .600 and 242 exhaust. My buddy Micah has the 6.0 heads that flowed 342 cfm @. 600 on the intake, these heads were ported by Race Prep Race-Prep.com they know their **** and will soon be a sponsor on this stie. Good luck.
Old Oct 11, 2003 | 01:17 PM
Brian Tooley Racing's Avatar
Our Judson Massengill signature series heads are 100% CNC ported in house. They flow 330 cfm @ .600" and start at $1999 and go up to $2399 depending on which type of valve train components that are used, and the ports are high velocity small port volume. If you don't know who Judson is I met him two years ago here in Bowling Green, he won King of the Hill running 9.90's on motor, all the big guys were there, their power adder motors either broke or got beat. Pretty amazing to see a guy beat a bunch of LS1 and LT1 power adder cars on motor!
