How do you repair valve kissed pistons?
i was running a .034 gasket with a 268/254 .693/.693 on a 114-1 lsa and it cleared my reliefs without a problem.
are you sure the cam is installed properly?
Have you all gone MAD?
The man never got the engine started and the PTV issue came when just turning it over. What happens when the rotating assembly gets to spinning while the engine is running?
Crankshaft deflection, centrifugal force, expansion from heat, valve bounce, and more is going to be the death of your ****. PTV will clearance itself no doubt and it comes in the form of bent or broken valves and taking out pistons along with any breakage. PTV clearance decreases with heat and RPM. YOU ALREADY HAVE ZERO PTV CLEARANCE WITH NO START UP!
How thick is your head gasket? How far in the hole are the pistons?
No just read this post of his so left it at that
Originally Posted by rufretic
Changing heads and possibly cam. I'm only worried about the fixing the pistons right now
Rufretic,
Given all the time and MONEY invested into your setup, I WOULD NOT RUN those pistons. You have no idea of the dimensions of the piston now, it could be warped from the contact, and or microscopic cracks forming. Also, given the looks of those pistons, its also possible your ring clearance in the ringland is too small now and givin heat, BOOST, can pinch the ring. You're talking about a lot of ifs, not to mention the problem with the timing of your cam being off. You need pistons with the proper valve reliefs CUT, not pounded by the valves. Didn't you measure your PtoV clearance?!
Take it with a grain of salt, but man, i'm tellin you, you don't want to f' this up.
Something isn't right for that to happen on startup. Are your heads milled? what's the dish on the piston? With a dished piston of any sort you should not have any PtoV issues at all, especially on a blower motor. Even with that cam, which looks horrible for boost IMO, you should have LOTS of clearance. You need to check everything on that setup because PtoV issues should not be happening at all.
Rufretic,
The pistons will be fine if you just de-burr them to relieve all the sharp edges. You may want to have them fly cut to match the cylinder heads you are running even if your valvetiming was off.
Kurt
Kurt
Yeah, that's what my first thread was about and I got a lot of negative responses like, "you can't run boost on fly-cut pistons" which I think is a bunch of bull ****. As long as I don't go deep enough to weeken the pistons I think this is my best option as well.
Relieved custom Wisecos... 20psi + a 100-150 shot... Brian Nutter and Dave Diluca (RIP) both said NO PROBLEM... You're only relieving a small area on the top land and the button... Mine are relieved into the DISH. If you've got a nice thick top ring land, taking a little out of it isn't going to be a problem. I'd have concerns about reliefs on a piston that wasn't BUILT for boost (ie: stock or off the shelf for a NA application), but not on what we're talking about... BTW - I'm running slightly less duration and very similar lift on a 114+4... No PTV issues on a 67cc AFR225, .054 Cometic, (9.4:1).
![](http://i258.photobucket.com/albums/hh274/crashinaz/408001s.jpg)
If you follow the radius on the refliefs in your pistons, you can see how much higher they are...
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
I'm going to start looking into how I can do it now. I'm not planning on going deep, just enough for some extra clearance and to clean up what I did with the valves.
Do you mind sharing some details on your set-up and how it worked out for you power/track. You can pm me if it's
![Secret2](https://ls1tech.com/forums/images/smilies/LS1Tech/secret.gif)
![Chug! Chug! Chug!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_chug.gif)
#33
rufretic.... why such a thin gasket with boost? why not just use stock thickness so you can keep a decent quench but allow yourself more room for **** like this.
I am assuming its something compressionr related that made you decide that but that just seems backwards to use a thin gasket and boost.
#34
#35
thicker the gasket the lower the compression, same reason you bought dished pistons, lower compression. The thicker gasket will give you that much more room on p/v clearence too.
But you dont want to go to thick because it will kill your quench area and increase the chances of detonation. I would suggest stock gaskets, thats my opinion though and thats what I will be using on mine, I dont really like messing around with gasket thickness it changes more things than just compression.
also with boost the less compression the more room for error such as bad gas, bad tune, glich in fuel control etc...
#36
Yeah, I understand the compression part. I actually wanted higher compression than what I would have with the -28 pistons, 72cc heads and stock gaskets. That put me at 8.4:1 and with these .04 gaskets I'm at 8.6:1, I wanted to be closer to 9:1 but that's tough with -28 pistons.
#37
ahh I see, damn thats alot of dish and alot of cc's in the head nice and low on the compression. around 8.5 is not bad though at all, when I was boosting imports the general rule was 9.0 was the highest the high end tuners wanted you to go they actually preffered the 8.5 range, so I wouldnt be to concerned about that small amount of compression, besides like I said it gives you that little extra bump in your safety cushion.
#38
