Check out this new style Intake manafold!
Old 11-30-2008, 07:40 AM
  #141
Restricted User
98Z28CobraKiller's Avatar
Originally Posted by beavis
I will have mine on Monday and hopefully my car will be on the rollers by the end of the week.
I dont know that on a forced induction application, it will make as much of a difference in terms of power. It's my understanding that the boosted cars dont have the intake stalling out limitations that us NA and nitrous guys have.
Old 11-30-2008, 01:42 PM
  #142
03 BUSA's Avatar
Originally Posted by 98Z28CobraKiller
I cant remember exactly but it was close to 700hp and about 680tq. This was thru a FAST90 which peaked at 6800 RPM. We wont have engine dyno numbers but we expect to pick up 50+ from this intake if it will allow us to spin the motor another 1K RPM. It's a pretty beefy cam in there.
Are you looking to use the current short runner intake or wait for the long runners for this motor?
Old 11-30-2008, 02:04 PM
  #143
beavis's Avatar
My power starts dropping off after 5k rpm. Doc Phil did testing on the L92/L76 and found out the combination makes no power above 6K. The write up is on the corvette forum.
Old 12-02-2008, 11:26 AM
  #144
Restricted User
one more week until ours arrives.
Old 12-02-2008, 01:05 PM
  #145
transAm-98's Avatar
Really curious to see some results on cathedral heads
Old 12-03-2008, 08:59 AM
  #146
Very Wild Bill's Avatar
Vinny,
Do you know how many are sold out of the second batch of production?
WB
Old 12-04-2008, 12:27 AM
  #147
Nitro Dave's Nitrous Outlet's Avatar
Originally Posted by Very Wild Bill
Vinny,
WB
We have about 4 to 5 that are not spoken for out of this up comming batch. Would you like to get on this batch?
Dave
Old 12-04-2008, 12:30 AM
  #148
Update
Guys when I get back from PRI I will put together the group purchase for the LS7 style.
For the guys needing the longer runners. They will be available real soon.
Dave
Old 12-04-2008, 02:28 AM
  #149
Dave
After some research, I will need the ones with the longer runners. My application requires the low-end torque. I'm hoping the longer runner version does not raise the plentum too much as I have aluminum over part of the engine and I do not want to redo that.
Do you know the runner length they are going to make for the longer ones?
Here are some pics of what I must work around.
Ideas...
Attached Thumbnails Check out this new style Intake manafold!-dscf0385crop.jpg   Check out this new style Intake manafold!-dscf0384.jpg
Old 12-04-2008, 09:54 AM
  #150
Jimmy P's Avatar
Ideas...
I haven't seen this intake in person, but right of the bat I can tell you that you probably will have to cut a little bit of that red aluminum piece so you can fit this intake. It looks prety tight.
Old 12-04-2008, 10:36 AM
  #151
860 Performance's Avatar
Update
Dave
well, I wouldn't say 'real soon' but we are working on it as fast as we can.
Old 12-04-2008, 11:04 AM
  #152
aNuBiS's Avatar
Here is a good question. Are the current runners, the length they are because that is as long as you could make them to still clear factory hoods? Or do you believe a longer set of runners will still clear factory hoods.
Old 12-04-2008, 11:11 AM
  #153
Restricted User
I may be wrong but I am thinking that the longer runner will be longer inside the intake not outside.
Old 12-04-2008, 11:15 AM
  #154
Restricted User
Eagerly awaiting our cathedral port intake. I hope there are no delays.
Old 12-04-2008, 11:18 AM
  #155
aNuBiS's Avatar
That is what I was hoping/thinking. But I was thinking it may possibly have to be on the outside aswell.
Old 12-04-2008, 11:36 AM
  #156
Yes, I can handle a little bit of trimming but not much.
I hope it will go inside too. Maybe a slight bend on the inside and 2 inches longer.
I hope not...
Old 12-04-2008, 11:57 AM
  #157
The longer runners do go inside, so the overall plenum dimensions will always be the same, which is only 1/2" higher than a stock manifold.
Vinny
Old 12-04-2008, 12:03 PM
  #158
Austin@HPE's Avatar
when will the batch thats being made deliveredto customers?
Old 12-04-2008, 12:11 PM
  #159
aNuBiS's Avatar
Vinny
Good to hear.
Old 12-04-2008, 12:24 PM
  #160
Good to hear.
Great.
Quick Reply: Check out this new style Intake manafold!
