How can I measure how far my heads are milled?
I know my heads were milled before I got them, but I have no idea how much.
Is there a way that I can find out?
They are L92's.
They are L92's.
I think the only way at this point to determine that would be to cc the combustion chambers. Someone else correct me if I'm wrong but I believe the L92's are supposed to be 70 cc combustion chambers + or - 1 cc. Once you get the size of the combustion chamber you can get a rough idea of what was milled. I just had .025 taken off my L92's and they were 65 cc's after being milled.
I bought them used, and the previous owner told me they were milled .020.
However the shop that built the shortblock said they were 64cc.
I know know who is right? Dont get me wrong, the 64cc would bump me in compression which would be great.
I'm trying to determine my CR, and also check the valvetrain geometry.
I have heard various ballpark figures for how many cc's the combustion chamber is reduced. I have seen .005-.007, for the sake of discussion, lets say .005 = 1cc, if they milled .020 off your heads and you started with 68cc chambers than you do have 64cc now.
The only correct way would be to check them now to see for sure.
Good luck.
Richard
The L92 heads are based on the same skeletal dimensions as the standard LS1&2 castings. The overall height of the heads measure 4.750" +or- .002". You can measure with a pair of calipers from the deck surface to the valve cover rail. Any less than 4.748" should be considered a milled amount.
Good luck.
Richard
Good luck.
Richard
