When does the Fast 92 become a restiction N/A
Old Nov 25, 2008 | 03:45 PM
03 BUSA's Avatar
Default When does the Fast 92 become a restiction N/A
Going solid roller NA 427. Will be a 50/50 car. I thought I would do a Fast 92 setup but the more I search it seems that it might be a restiction on a NA build. Don't get me wrong the Fast setup is much cheaper but at the same time I don't want to spend the money on a Fast if I will just be swapping to the sheetmetal in the future. I want to do this build right the first time and not look back. I was going to make this thread a poll but I knew people would vote on the sheetmetal without actually owning one or knowing the real effects. Wanted some thoughts and opinions on what you are running with your NA big ci builds. Thanks guys.
Old Nov 25, 2008 | 04:22 PM
aNuBiS's Avatar
Well I have an n/a 418ci solid roller ls3. I have a ported fast 90/90 and put down 522rwhp thru small 1-3/4" headers in an automatic with a big stall and ford 9" rear-end. Do I think I could make more with a sheetmetal, yes.
Question is, are you willing to sacrifice some low end torque for some high rpm horsepower.
Old Nov 25, 2008 | 04:45 PM
03 BUSA's Avatar
Well sure there would be a trade off for more pk hp but also I think the sheetmetal would allow the motor to turn farther as well. Question is how far does the fast allow the motor to turn? I think a sheetmetal would net in the low 7k's. Not real sure but would a fast allow that?
Old Nov 25, 2008 | 06:24 PM
aNuBiS's Avatar
I shift at 7000rpm(peak) and the motor holds good 7500rpm. I want to pick it up higher and raise the peak.
Old Nov 25, 2008 | 06:36 PM
03 BUSA's Avatar
So for a weekend street driven toy that I could take to the track and shift at 7200 the fast would work for my application? Thanks again for the help. I am looking at a Fast 92/Beck and the new Fibertuned intake once long runners are avail. I won't be in the market till sometime in Jan but trying to get all the research done now so I have a plan.
Old Nov 25, 2008 | 06:40 PM
2000_SS's Avatar
the FAST will definately have to be ported, or it will be a waste of money to an extent.
Old Nov 25, 2008 | 06:48 PM
03 BUSA's Avatar
See in my opinion that would make it a waste, by the time you put the time and money into having it ported I would rather dish out the 1650 for the new fiber tuned intake with long runners and be done.
Old Nov 25, 2008 | 06:54 PM
2000_SS's Avatar
that's precisely what i'm doing, but i have sheer cubic inches to feed (454) and it's not that a FAST won't work, it's just that the fiber-tuned intake will, presumably, do better. the power loss down low will be minimal and due to the physical size of the motor, it won't be noticeable. it'll be traction control if anything else.
...but on the other hand, i wouldn't put a FAST on anything without porting it, assuming the car has your other "typical" mods like cam, headers, etc...i do my own porting, so the gains are really worth the cost - which is just a saturday afternoon in my case.
Old Nov 25, 2008 | 07:04 PM
03 BUSA's Avatar
You getting the short runners or waiting for the long runners to come out?
Old Nov 25, 2008 | 07:17 PM
yelnatsch517's Avatar
Fibertune intake suffer from heat soak?
Old Nov 25, 2008 | 07:20 PM
03 BUSA's Avatar
No, hence the fiber runners to dissapate heat better that a 1 piece sheetmetal.
Old Nov 25, 2008 | 07:23 PM
tektrans's Avatar
If it does it should be alot less than an intake that's all metal. I'm thinking the carbon runners will help alot with that.
Old Nov 25, 2008 | 07:34 PM
2000_SS's Avatar
i'm sticking with short for now. no need to maximize a 454cid motor in a 'mostly' street car...the cam is already spec'd & ground for this one anyway.
Old Nov 25, 2008 | 07:59 PM
03 BUSA's Avatar
I think your backwards or I am. I thought the short runners were for high rpm like 8500 and so and really kills low end vs the long runners for some street use and minimal low end loss. Atleast that's what I got from talking with Nitrous Dave tonight.
Old Nov 25, 2008 | 08:34 PM
2000_SS's Avatar
may be...
either way, i'm going to order whatever is available when i'm ready to order...not exactly the best philosophy when building an engine, but the one that is out now, is what my cam is spec'd for. the car it's going on isn't a racer or a DD...just a toy...a violent, nasty toy
Old Nov 30, 2008 | 08:13 AM
98Z28CobraKiller's Avatar
Restricted User
The FAST intake typically peaks out at 6400 RPM on most hydraulic application builds that I have seen. We engine dyno'd a new solid roller 427 LSX block that we just put together. The peak carried to 6800 RPM (but this is a REALLY big cam). I dont have alot of experience with the engine dyno so I dont know exactly how this will translate to peak numbers on the rollers. On the engine dyno, you have nothing in front of the TB. IMO, there is no point in incurring the additional expense of building a solid roller setup if you dont intend on spinning it over 7500RPM. If the Fast stalls out at 6400 RPM (go in the dyno section and look at some graphs, that's about it for the FAST), there is no point in spinning it higher than 7K.
Another thing that I noticed is that none of the guys that are going 9's NA are running FAST intakes unless the cars weigh less than 3100 lbs.
So I personally think that the FAST is not for you. I need to sell mine cuase it's not for me either.
Old Nov 30, 2008 | 12:09 PM
SOMbitch's Avatar
Edelbrock just debuted a short runner intake at SEMA and are making some pretty bold claims. May want to look into it before you make your decision. It is scheduled for a January release and is only in the $400 range.
Old Nov 30, 2008 | 12:41 PM
aNuBiS's Avatar
I was under the impression that one didnt clear factory fbody hoods...
Old Nov 30, 2008 | 02:45 PM
BigRich954RR's Avatar
Id stay the fiber tuned intake might be better for you. I dont think you being giving to much up in the low end par with a soild rolle.
Old Dec 2, 2008 | 11:11 PM
blackonblack02_Z's Avatar
So what intake, or intakes would be preferred for a 427ci engine turning 8500 in a 3600lb car?
