98.3mm sleeved LS7 intake pics
Old Feb 20, 2009 | 08:04 PM
AlphaLS1's Avatar
Default 98.3mm sleeved LS7 intake pics
98.3mm sleeved LS7 intake manifold pics.
Attached Thumbnails 98.3mm sleeved LS7 intake pics-98.3-mm-throat.jpg   98.3mm sleeved LS7 intake pics-98.3-mm-top.jpg
Old Feb 20, 2009 | 09:23 PM
alocker's Avatar
What are you going to use to seal the throttle body?
Old Feb 20, 2009 | 10:50 PM
AlphaLS1's Avatar
A thin film of RTV is all that's necessary. The seal is good enough it takes some effort to separate the throttle body from the manifold.
Old Feb 20, 2009 | 10:59 PM
Troux's Avatar
Any room to hit the magic 100 number?
Old Feb 20, 2009 | 11:28 PM
AlphaLS1's Avatar
Yes, the manifold's flange/throat area has enough plastic that a thin wall tube with a 100mm ID will fit. I used a length of 4" exhaust tube with a 98.3mm ID because it was convenient. Also, the largest I could bore my NW 90mm throttlebody was just over 98mm so going to the trouble of sleeving the throat to a full 100mm wasn't worth it in my case.
Old Feb 20, 2009 | 11:38 PM
one fast zo6's Avatar
Default ls7
NICE WORK!!!!!!!!
Old Feb 21, 2009 | 01:53 AM
Haans249's Avatar
That right there is really cool. I sent a PM to ya.
Old Feb 21, 2009 | 07:28 AM
ramairws6's Avatar
Cool! I was going to attempt this until I spoke to quite a few head and intake guru's that explained that even if I would open my intake up I wouldn't gain any horsepower over what I have now?
Old Feb 21, 2009 | 09:43 AM
AlphaLS1's Avatar
ramairws6, you have a classic restrictor plate combination. A big high rpm engine, an intake manifold with relatively large runners that match the large LS7 intake ports and a big throttlebody. Between the 100mm throttlebody and relatively large intake plenum you have a 92mm intake throat. Manifold pressure at high rpm WOT with that restriction removed has to be higher.
The head porters you talked to probably don't offer a solution to the 92mm throat so they may have simply been saying we don't offer it so you don't need it. Otherwise, they would be recommending a FAST 80mm intake with a large throttlebody as a sweet setup.
Old Feb 21, 2009 | 01:00 PM
ramairws6's Avatar
Actually after my intake was ported and the throat cleaned up I am at or around 94-95ish mm opening. I do have a slight ridge or lip by the o-ring that I don't care for. I know it's not helping me any but don't have a clue if it's hurting me either!? I would also think that the true 100MM opening with my 100MM throttlebody would help but who knows??
Old Feb 21, 2009 | 03:21 PM
98Z28CobraKiller's Avatar
Restricted User
Would love to see a back to back dyno of this before and after. I don't think that it will gain anything unless you are making over 1000rwhp. A 90mm throttle body can flow ALOT of air.
Old Feb 21, 2009 | 04:26 PM
Haans249's Avatar
He will certainly gain. It may not be 15rwhp, but certainly something. I've seen before and after results, just can't remember where. Gained 6 rwhp, and about 5 rwtrq. So, every nickle and dime counts!
Old Feb 21, 2009 | 04:35 PM
AlphaLS1's Avatar
The trend is to go larger and larger. The post in the Dyno Section shows a gain going from a 90mm to 95mm throttlebody without increasing the throat size. Also, FAST's pending LSX/R manifold will accommodate a 102mm throttlebody.
Old Feb 21, 2009 | 05:56 PM
ramairws6's Avatar
Sure would like to have a back to back comparison. I'm figuring maybe a 3-5 horse increase but who knows??
