L92 Intake?
Old May 13, 2009 | 04:59 PM
GIGJR's Avatar
Default L92 Intake?
What intakes (fuel injected) can be used with the L92 heads now that the L76 intake package is discontinued?
Old May 13, 2009 | 05:45 PM
bottelfed377's Avatar
When and why did they discontinue the l76 intake?
Old May 13, 2009 | 06:55 PM
SweetS10V8's Avatar
LS3 for cars (Corvette), L92 for truck(Escalade).
Old May 13, 2009 | 07:24 PM
8ByGoat's Avatar
Want me to start now or later LOL.
Old May 13, 2009 | 08:15 PM
SweetS10V8's Avatar
About the one that's 2 years late, with zero explanation. Or the one that's one month late, and has come forth and explained in detail what is happening.
I respect them coming on and explaining things. They literally came on the forum and answered because you kept asking, you have to give them credit.
Old May 13, 2009 | 08:27 PM
8ByGoat's Avatar
It was good of them to come on the board and finally say something-it is a definite improvement from the 1st aftermarket intake that was suppose to be available 2 years ago..
But just to clarify, the intake in question, was originally suppose to be available to the public in January-when this wasn't met it was then changed to April.
Obviously I hope I am wrong. But this is the same pattern that the 1st intake followed (granted in the infant stages-but nevertheless).
Old May 13, 2009 | 09:00 PM
SweetS10V8's Avatar
Its clear that wont happen.....
Originally Posted by horsepower
First, let me make it clear - we want these manifolds finished as much as all of you, and we are fully committed to these manifolds. There is absolutely no gray area, these manifolds will exist - and we're very close. Internally, all efforts are pushing as hard as we can to get these done and in stock, both LS7 and LS3 versions.
Old May 13, 2009 | 09:51 PM
GIGJR's Avatar
I work for a Chevy dealer and had our parts mgr research the intake kit only to find it is discontinued with no replacement coming. Has anyone heard different? It can be bought piece by piece for around $1500 instead of $600 for the kit.
Old May 13, 2009 | 10:07 PM
CharlieC's Avatar
Just for grins, I called FAST yesterday to ask about the L92-102 and was told Aug/Sept.
Charlie
Old May 13, 2009 | 10:13 PM
sroach20's Avatar
you can piece it together for cheap. i got an ls3 intake off ebay for $110 shipped. you can also go with an l76 intake.
Old May 14, 2009 | 10:03 AM
8ByGoat's Avatar
Charlie
LMAO.
Exactly what I said in the other thread (August).
Old May 28, 2009 | 07:37 PM
Rock_Daddy's Avatar
I'm gonna try this setup out
I think its purdy...
Old May 28, 2009 | 08:07 PM
SICKSS/Z28's Avatar
looks good for a race car but if you have a hard time getting races with a plastic intake try that lol is that a 4150 or 4500?
Old May 28, 2009 | 08:23 PM
Rock_Daddy's Avatar
Yes It isn't for everyone, or every hood. I just had to show it off though.
Its a 4500!
Old May 28, 2009 | 08:26 PM
SICKSS/Z28's Avatar
Its a 4500!
BAD *** personally i would roll no hood its not illegal
ps will that fit under the 4" cowl for f-bodys?
Old May 28, 2009 | 08:31 PM
Rock_Daddy's Avatar
Actually I don't know if it would fit under that hood. This is a transplant into a Vega drag car. Here is a pic of it on the engine so it can give you a better look.
Old May 28, 2009 | 09:13 PM
SICKSS/Z28's Avatar
what did it put down to the crank?
Old May 28, 2009 | 09:19 PM
Rock_Daddy's Avatar
Well it had an issue on the dyno last Monday and had a rod beat the crank up. The crank is being turned and a rod being replaced. No clue what happened, just one of those things.
It has bone stock L92 heads except the springs and the first un-tuned pull was 576hp at 6400rpm. It should spin to 7200rpm when everything is working correctly I think. I hope that number goes up! (I bet it will)
It should run again this coming Monday I hope.
Old May 28, 2009 | 09:25 PM
Rock_Daddy's Avatar
Didn't want to get off topic on the thread so this is another L92 intake option!
Thx for the great job on the intake Cary! (Performance Induction)
Old May 29, 2009 | 08:56 AM
Robin L's Avatar
LS1Tech Sponsor
SDPC recieved a batch of complete LS3 intakes. Check and see if they have any remaining. GMPP will re release the LS3 intake kit very shortly.
Robin
