Rods dont clear Canton oil pan in the front
Old Jun 20, 2009 | 08:55 PM
2000_SS's Avatar
Angry Rods dont clear Canton oil pan in the front
I finally got my windage tray to clear all the rods like i wanted and still have enough stud sticking out the tops of the nuts to make me happy and i go to fit up my oil pan and the front two rods hit the freakin' pan
What do you all think i should do? Cut out the part where it hits and weld in a new piece that will allow clearance? try a different brand of oil pan? sell it and buy a stock one? ditch the whole build and buy a Prius?
Old Jun 20, 2009 | 08:56 PM
2000_SS's Avatar
....and for reference, this is a 454 LSX, 4.125" stroke / 6.2" rod...
Old Jun 21, 2009 | 01:05 AM
Gordon0652's Avatar
If you cut and weld a piece there you would need to taper it down to the main stump because if you do not, oil will just puddle there.
I am going to have the same problem with my 440 LS7 that i bought for LME. They told me something how to fix that, i do not remember what they said, but give them a call and i am sure they will help out!
What oil pan do you have that is not working ? so i can stay away from it.
Old Jun 21, 2009 | 01:09 AM
Gordon0652's Avatar
Forget my question, i see your using the Canton oil pan in the topic.
Old Jun 21, 2009 | 10:09 AM
2000_SS's Avatar
i think this is just a common problem with high-end, large displacement motors...i'd say 95% of aftermarket parts are designed with stock stroke or 4" stroke combos. i've not been working on it as much as i'd like, but the last two or three times i have, it's been trying to make the windage tray clear. i finally got it where i like it last night and it just so happened that when i stopped rotating the engine, the first two rods where at the bottom of their stroke and hit the pan when i test fitted it
Old Jun 21, 2009 | 11:37 AM
XtraCajunSS's Avatar
The Canton pans are notorious for that problem. I would try the Moroso pan. It is a much nicer setup for high end strokers anyway with a much better sump design with a new pickup and windage tray included. It also has a 3/8" pan rail and the AN fittings are already welded in place. Its not on our website but we do have them in stock.
Thanks,
Shane
Old Jun 21, 2009 | 11:42 AM
2000_SS's Avatar
Thanks,
Shane
Thanks Shane, i might look into that. I've yet to add TR to my list of vendors on this particular build, i might pick one up if i sell my Canton pan. So you think the Moroso will clear my 4.125" stroke? what about the windage tray? will it clear? if not, i can make it clear or just use the one i already have, not a big deal. Do you have a part number and price for that Moroso pan?
Old Jun 21, 2009 | 12:05 PM
2000_SS's Avatar
Moroso part number 21150? cheapest i can find is $620 from Summit
Old Jun 21, 2009 | 12:22 PM
That's the part. It should clear the 4.125" stroke with steel rods. I'm not sure what our price is since I'm not in the office right now. I know I have one in stock though. Let me know if you need anything. I have one on an LS7 based TransAm at the shop. I could send pics with the remote oil filter setup and such.
Thanks,
Shane
Old Jun 21, 2009 | 02:51 PM
Gordon0652's Avatar
Yeah...
& i want the same oil pan for my 440 and i do not really feel like spending 620$...
Shane @ TR come through with something...
Old Jun 22, 2009 | 04:23 PM
2000_SS's Avatar
i think an item like this would be difficult to mark down enough for most of us to buy it on a whim...but if we could get a GP together it might make it worth a vendor's time/effot. i can't imagine that there are enough people around needing a $5xx or $6xx oil pan right now...probably just going to order one from summit after i sell mine i guess...
Old Jun 22, 2009 | 05:20 PM
Gordon0652's Avatar
I just ordered mine from LME for 600$, includes pan, pick up tube, and windage tray. They are also going to modify it to it will work for my stroke. 4.100"
Old Jun 22, 2009 | 09:18 PM
99blancoSS's Avatar
go with the prius
Old Jun 23, 2009 | 04:06 PM
2000_SS's Avatar
Originally Posted by 99blancoSS
go with the prius
...on 2nd thought, Prius with a 454 .....
Old Jun 24, 2009 | 09:12 AM
2000_SS's Avatar
it still needs modifing with a 4.1"? how much modifing is required? i've got another .025" of stroke to deal with, not much, but it counts. do you have any pics or info from them about what has to be done to it?
Old Jun 24, 2009 | 09:26 AM
2000_SS's Avatar
....and is there NOT a pan that will clear a 4.125" stroke?...besides the stock one...or will it even clear? i know i'm not the only one to have had this problem...
Old Jun 24, 2009 | 10:43 AM
Gordon0652's Avatar
All they said they had to do was grind the windage tray a little. Nothing to the pan itself.
Old Jun 24, 2009 | 11:08 AM
2000_SS's Avatar
grind the windage tray a little? i had to put 4 washers uner it on each main stud AND beat the living **** out of it with a hammer for it to clear my rotating assy:
you can see here how it looks 'ballooned' out, that's because it is, a LOT. it's actually kind of hard to tell just how much i had to do it to without a stock, unmodified one next to it, but it's a LOT...
and here you can see where the rod BOLTS (not the rod itself) hit the pan in two places. it hit then stopped, if it were able to keep turning, i would imagine it would puncture the pan:
Old Jun 24, 2009 | 11:10 AM
The Moroso pan and windage tray should clear no problem. I know the price sounds steep but as far as I know, its the only option that will work without major modification.
Shane
Old Jun 24, 2009 | 12:45 PM
2000_SS's Avatar
i guess i'll go ahead and sell the Canton pan if i can. what i hate about the whole deal is, i'm going to have to lose a little money on the Canton pan to get rid of it, and on top of that, IF the Moroso pan DOESN'T work for some reason and i have to sell it for a stocker, then i'll lose money on it too i'm sure. i hate to do crap like that, i just wish i knew definitively that the Moroso would work. Gordon0652 says it works on his 4.100" crank, but mine is tad bigger, 4.125", and a different block/crank/rods/bolts...it might NOT fit, knowing my luck lately anyway
