500ci ERL Super Deck?
Old Sep 18, 2009 | 04:14 AM
  #41
kumar75150's Avatar
Originally Posted by racer7088
You don't need any 500 cfm head to make more power on a 500 inch LS1. Who cares how much hp per inch you are making when hp by itself it what matters. The 500 inches brings the power for even a 420 cfrm head down to an rpm level that can really live on the street. This is what the bigger street engines are about plain and simple not ultimate hp per inch.
very well stated Eric. no one is looking for a "perfect world" setup. with the same top end, the bigger motor will outperform the smaller motor. it's as simple as that.
i will be getting in touch with you about a 5.4L mod motor this winter
Old Sep 18, 2009 | 04:17 AM
  #42
kumar75150's Avatar
btw, im hoping to get some numbers out of my ERL 500ci motor anyday now. pump gas, hydraulic roller, daily driven c6.
trying to fit the headers and mid pipe has been a pain in the ***
Old Sep 18, 2009 | 04:37 AM
  #43
Nimitz87's Avatar
Originally Posted by NemeSS
it would take some heavily worked on c5r heads and a matching sheetmetal intake, but even then i doubt they would flow enuff to feed a 500ci engine, but it sure would use em up and still make impressive power
that's what's on the SAM car I believe, highly worke c5r heads, with twin 4150's IIRC and a sheet metal.
I agree with the guy saying there isn't a head out there to flow w/ the higher cubed motors....yet.
Chad
Old Sep 18, 2009 | 04:38 AM
  #44
Nimitz87's Avatar
and what heads are you putting on this beast?
sheet metal intake?
Chad
Old Sep 18, 2009 | 06:37 AM
  #45
kumar75150's Avatar
LS7 heads and a FAST
It's a daily driven street car.
Old Sep 19, 2009 | 04:11 AM
  #46
racer7088's Avatar
I think it will be a nice combo!
Old Sep 19, 2009 | 04:36 AM
  #47
Beaflag VonRathburg's Avatar
OWN3D BY MY PROF!
Originally Posted by Zac_Speed
FWIW Thomson Automotive built a 400ci. LSX block with the prototype DR LS heads and with twin turbos made 2048 hp or something close to that. It's an aluminum rod motor so I'm sure some H-beams could be thrown and and knock the MAX RPM Down a notch.....
I want to know when those heads are going to be released for public purchase.
Old Sep 19, 2009 | 06:23 PM
  #48
LS6427's Avatar
Gonna be interesting to see if it puts down the same RWHP or close...to a 427-454ci with ported LS7 heads and a FAST/LS7 intake set-up.
I'm thinking its gonna be right around the same power. 600-625 RWHP, maybe a little more.
When do you think it will dyno?
CR?
Cam specs?
tranny?
Gears?
Old Sep 21, 2009 | 10:53 PM
  #49
kumar75150's Avatar
around 258/268 and .700 lift
c6 z06 with stock 3.42
if it makes under 625, i will be very disappointed. i know peak hp isn't the only factor with this big of a motor but still....
for future comparison purposes, i consistently trapped 136-137 on my 427 making 590rwhp in +800 to +1000 DA.
Old Oct 1, 2009 | 09:09 AM
  #50
Andrew91GT's Avatar
11.8:1
Any results?
Old Oct 1, 2009 | 10:44 AM
  #51
niceguyyy01's Avatar
I am definitely curious to see what it dyno's, but I will bet that if your similar 427 combo dyno'd at 590rwp.... my guess will be 681rwp with the same heads intake combo. What do I get if I win? LOL.
Old Oct 4, 2009 | 07:57 PM
  #52
kumar75150's Avatar
^ i wish...im thinking that's close to where we will eventually end up. 675 would be nice. i think 700 is definitely possible with this bottom end if you go all out and spend the money on All Pro heads, custom intake manifold, etc. fun stuff.
results for now are 650hp/600tq
kpa reading of 93 up top with the fast 102 intake and ls7 tb
ordering a NW 102mm TB. other than that, i just want to drive the car around for a while. i probably wont race it til the spring anyway so we'll **** with other stuff later. maybe a bigger cam, custom airbridge/air filter setup, maybe speed density, cutouts etc. i dont wanna get rid of the stock NPP catback.
also, from what i was told by the shop, ERL sent us a cam they liked instead of the cam we specced out. kinda annoying if true. who knows. it definitely idles better and lopes less than my 427 did. hopefully at least the comrpession ratio is where i wanted it.
Old Oct 4, 2009 | 08:04 PM
  #53
kumar75150's Avatar
i left my heads alone cause honestly didnt want to **** with them but maybe opening them up more for the bigger motor will help also...
Old Oct 5, 2009 | 03:06 PM
  #54
ringram's Avatar
Are you sure the kpa reduction isnt because of your intake filter or tract?
Or did you log it with no air intake connected to the throttle?
If so sounds like you need at least to port the 90mm throttle. Let us know how the 102mm throttle goes with that.
In theory a gain of 6 kpa could give you 5%+ more power
What was your total timing at wot?
Old Oct 5, 2009 | 05:14 PM
  #55
LS6427's Avatar
Is that 650hp with an engine dyno or chassis dyno????
Old Oct 5, 2009 | 05:17 PM
  #56
kumar75150's Avatar
at the wheels
on a dynojet
Old Oct 5, 2009 | 05:18 PM
  #57
kumar75150's Avatar
nope, not 100% sure
next plan of attack is to start with the 102mm tb and see if we need to build a custom pipe from the tb with a big filter on the end. no idea right now.
ill ask my tuner about timing when i pick up the car on wednesday
Old Oct 5, 2009 | 05:42 PM
  #58
LS6427's Avatar
nope, not 100% sure
If you have the cash, get an ITB intake. You'll get close to or over 700 RWHP. There's a 454 LSX iron build with one that made 742 RWHP. Street friendly cam.
650 RWHP is pretty good though, with that top end.
Old Oct 5, 2009 | 06:01 PM
  #59
kumar75150's Avatar
link to this 454 build?
ITB is currently too much of a pain in the *** for a street car IMO: https://ls1tech.com/forums/generatio...installed.html
If it was a simple plug and play application with documented gains, I would think about it.
Old Oct 5, 2009 | 06:32 PM
  #60
LS6427's Avatar
Its easy to tune and it makes for a great 600rpm idling street daily driver on his 454ci. You just have to know what your doing to tune it. The owner of the 454ci engine in the video is also the tuning expert that owns Waitformeperformance.com that did the tuning. That intake made 65 hp more than his FAST 90/90. 61 more than his Wilson sheet metal.
Don't see how anyone can ask for a better idle than that for a big cube engine.
Heads flow 372cfm at 650. Modified AFR 245's.
Final Cam specs are 650lift 260 duration @50 on a 114ls on 1.7 ratio
He obviously has less drivetrain loss than we would because of that tranny he's using.
http://videos.streetfire.net/video/G...a-997e016f9480
http://videos.streetfire.net/video/J...car_182870.htm
