500ci ERL Super Deck?
Old Oct 6, 2009 | 06:14 AM
  #81
Quick Carl's Avatar
Congrats Kumar. I am with you with how loosely the 600+ HP number is thrown around like everybody is making that on NA pump gas. But when you search like this deal you see that it's high compression E85 or can't idle because of a huge cam or ??? The best test is to go to the track if you can't dyno the engines side by side on the same dyno on the same day. Dyno's are like flow benches.
I believe the broad power range in drivability will be quite a difference. If 46 additional CI over a 454 makes the same power per CI then your on track. If someone wants to take advantage of the bigger bore and unshroud the valves from the 4.125" they were limited to initially then you may see additional gains. I do believe the 90mm Throttle body is hurting even on the 102 intake from your KPA #'s.
Old Oct 6, 2009 | 08:24 AM
  #82
briannutter's Avatar
Hilarious. These thread reads just like the old early 2000's threads with people bantering about the virtue of spinning a stock stroke high versus the 4" strokes having "crazy piston speeds" and "heads that don't breath enough" and "torque breaks things".
Time marches on and within the next 5 years 4.500 stroke engines will be the new 427 and won't cost anything more than a 4" stroke engine. Right now there is exclusivity and R&D to be paid for, but the cost of the components themselves isn't much different.
Old Oct 6, 2009 | 10:37 AM
  #83
racer7088's Avatar
Definitely the TB will help you a bit Kumar if you are pulling vacuum on top. Bigger is still better in my book everytime as long as parts can handle it!
I agree with Brian as well as these newer blocks coming out have the ability to handle more stroke than before and there is no reason not to use it!
Old Oct 6, 2009 | 12:26 PM
  #84
kumar75150's Avatar
thanks guys
the TB and custom airbridge/CAI are next on the agenda
maybe next spring I will spend the money on a new top end. want to see more results from the All Pros. i honestly dont know enough about my current LS7 heads and how much work was done to them by LG to say if they are holding me back.
in summary, i went with this setup because i cracked my original LS7 and it only costs $3000 more to get a built 500 than a similarly built 427-443.
now it's time to build the motor in the other car
Old Oct 7, 2009 | 04:07 AM
  #85
LSX350Z's Avatar
Originally Posted by kumar75150
you're putting this in a 350z? that should be nuts
Kumar,
I pulled the trigger and ordered the LPE GT21 camshaft. As for the heads I am still going to see what west coast cylinder heads has to say. Thanks for the advice. More then likely I will be using the Ferrea high performance dual valve springs, titanium retainers & valve locks to complement the cam.
Old Oct 21, 2009 | 10:59 AM
  #86
Stage7's Avatar
Any updates Kumar?
Old Oct 23, 2009 | 04:30 PM
  #87
Bandit28's Avatar
WOW, everyone must be making 600+ with their NA 427s these days... Cant wait til ERL gets away from the stockish cam and bumps up the compresion quite a bit, then this 500ci will really be showing what it is capeble of.
Old Oct 24, 2009 | 11:33 AM
  #88
Reckless's Avatar
Super Moderator
I should have them before the weekend even though it has been raining non stop here.
Dang Kumar...that's quite a stable you got there young man!
Old Oct 27, 2009 | 02:54 AM
  #89
kumar75150's Avatar
Originally Posted by Stage7
Any updates Kumar?
Not really. Was concentrating on the other car and the Texas Mile.
The 102mm TBs were on backorder. Finally back in stock but I'm in no hurry now with the winter fast approaching. I'll be happy if the car consistently lays down 650/600 with the TB and speed density tune. Should be plenty to make a 9 second pass. The next big step would be better heads but this isn't an all out build and I'm too lazy to do more testing unless someone else shows me a 700rw combo.
Old Oct 27, 2009 | 03:06 AM
  #90
kumar75150's Avatar
Hey Todd
Old Oct 27, 2009 | 10:46 AM
  #91
racer7088's Avatar
Kumar, You probably know more than I do since you are waiting but doesn't ERL themselves now have a 102 TB as well or is that the one you are waiting on? My computer is going crazy so I can't read this whole thread.
Old Oct 27, 2009 | 02:11 PM
  #92
kumar75150's Avatar
Hmmm, I havent heard anything about that. I assumed the Nick Williams unit was the only one out there.
Old Oct 27, 2009 | 02:47 PM
  #93
racer7088's Avatar
I'd give them a carl but I am certain that they had one now too?
Old Oct 27, 2009 | 03:47 PM
  #94
FMS_FTW's Avatar
Restricted User
http://www.erlperformance.com/index....&Itemid=100016
Old Oct 27, 2009 | 05:00 PM
  #95
Nimitz87's Avatar
I know rev Extreme also has larger throttle bodies...105, 110, etc.
Chad
Old Oct 27, 2009 | 05:13 PM
  #96
racer7088's Avatar
Damn I meant "call"!
Old Oct 27, 2009 | 05:33 PM
  #97
NemeSS's Avatar
thers thread here somwhere about newly released 102mm ERL tb
Old Oct 27, 2009 | 05:45 PM
  #98
kumar75150's Avatar
i was about to go look it up on urban dictionary
Old Oct 27, 2009 | 06:20 PM
  #99
kumar75150's Avatar
https://ls1tech.com/forums/generatio...ttle-body.html
im guessing they want something outrageous for it or production units arent ready yet
Old Oct 27, 2009 | 08:55 PM
  #100
Bandit28's Avatar
Yep they sure do, it is all plug n play with the factory harness.
