Milled L92 Heads...?
Old 09-11-2009, 05:14 AM
frankmarroquin's Avatar
Default Milled L92 Heads...?
By anychance does anyone know how much I would be able to mill down some L92 Heads to run on my 6.0 LQ9 Motor(Flat Top Pistons), Torquer V2 Cam(Maybe MS3 later).... I wanna raise the compression on my motor. Currently I have 243's on my LQ9.
Old 09-11-2009, 06:41 AM
SweetS10V8's Avatar
I wouldnt mill them at all. I cant tell you anything specific because names of camshafts means nothing. Specs are what people need to help you, not names.....
I milled my L92 heads .030 and couldnt fit bigger than a 219 duration intake lobe and Im sure your cam choice is bigger than that. It also depends on the lobes on those cams, I have an LSR cam with LSL lobes which are fairly aggressive. If you get a lazy/slow cam you might be able to fit a little more. Remember, True flat top + gigantic intake valve = not much PTV, mill the heads or change to thinner intake gasket = even less!!
Hot Rod Mag just did an article with 5 Comp cams and unmilled they mentioned the biggest they could fit. I dont remember what cam it was though... Look it up if you want, they made 525ish FWHP IIRC.
Either way, you MUST check PTV with any camshaft install, because your paying the bill if it crashes no matter what anyone says on here....
Old 09-12-2009, 09:54 AM
Andrew91GT's Avatar
L92 heads are a 70cc head, right? You would have to mill the snot out of those to raise compression compared to an 843.
Old 09-12-2009, 06:14 PM
tektrans's Avatar
Yeah like 72cc I think.
You would have to notch the pistons, it can be done, how much I don't know, depends on how much piston material you have left to notch.
I would just get a set of different heads if you want to up that cr a bunch.
Old 09-12-2009, 06:51 PM
8ByGoat's Avatar
Wrong.
Guy on ls1gto just got 23rwhp and 16rwtq by doing nothing more than milling the heads .0030 and running a thinner gasket. Info is here...
http://www.ls1gto.com/forums/showthr...=1#post6024970
Old 09-12-2009, 09:58 PM
SweetS10V8's Avatar
Originally Posted by 8ByGoat
Wrong.
Its an opinion, I cant be wrong.
I would rather have the PTV clearance for the option of a larger camshaft. It depends on what you want....
The heads already flow well, matched with a good cam will make great power. Compression is one of the last things on my list of importance for a street vehicle. 10:1 is perfectly acceptable for a decent street engine.
Old 09-12-2009, 11:42 PM
the_merv's Avatar
Stock L92's are about 71cc. I had mine milled down .025", and they are a hair under 66cc Chambers.
Old 09-12-2009, 11:53 PM
Gregory's Avatar
You could measure your current head surface to valve depth on your heads and then compare that measurement to the new L92 heads. Doing so will give you a good idea how much change you have with just a head swap. You would need a micrometer style depth gage for accurate results.
So, if there is a .050” difference between the two heads and your current camshaft clears, it would seem reasonable that you can mill off .050” safely. Check a couple valves on each head as sometimes there are variances.
I had about .066" milled from a set of 243 series heads and still have room on -14cc pistons. Another .018" will come off in the future. The pistons and valves are clayed for clearance with a .037" gasket. Specs on the camshaft are below.
Old 09-13-2009, 07:17 AM
SweetS10V8's Avatar
You have to take into consideration that the valve size has changed dramatically(2.00" to 2.160") which reduces PTV. Plus he going to a larger camshaft the also reduces PTV. Any milling or head gasket changes reduce it even more. You can see why you run out of room fast with these heads and stock pistons.
Your theory would be more likely true if he were keeping the same heads and same cam.
I always check PTV with a solid lifter, adjustable pushrod, checking spring, and a dial indicator
Old 09-13-2009, 11:27 AM
8ByGoat's Avatar
OP has a 364ci engine. So why on earth, would he care about running a "larger" camshaft? "Larger" camshafts have been proven to barely make (and in a lot of cases not even) the #'s that "smaller" to "midsized" camshafts when coupled with a 6.0 bottom end and L92 heads.
And if you would reread his original post, he wants to raise the compression.
Old 09-13-2009, 12:25 PM
69LT1Bird's Avatar
Check how far the pistons are above the deck first, measure all of them, they can vary. This will help you determine everything else. LSx based engines are between .004 and .010 above the deck.
The flat tops will cause you issues because valve reliefs, get some cut and you can do what you want.
Old 09-13-2009, 01:48 PM
SweetS10V8's Avatar
Your trying way too hard here.... stop trying to start fights and start helping people......
Like I said, from my personal experience when I milled .030" I couldn't go larger than a 219 duration on my intake. "Larger" then refers to cams larger than 219, say 220-228(ish).
He may want to raise compression, but he most likely can not with those cam choices because of piston to valve clearance.
Old 09-13-2009, 02:13 PM
BES Stroked Nova's Avatar
I make 525 whp with milled L92's and a 242/246 custom cam. on a stock 6.0L bottom with valve reliefs. I picked up 55 whp with a very mild port job, milled heads and the change to this cam from a MS4...
it can be done. Mine are milled .070" and compression is around 11.0. I also run a GMPP l92 intake and a edelbrock elbow.
Car runs 11.0's at 125, 3775 lbs. 6 speed..... heads can be made to work.
Old 09-13-2009, 02:37 PM
xdanny510x's Avatar
i milled mine to about 64cc and im pretty close to a 12;1 compression
Old 09-13-2009, 03:12 PM
SweetS10V8's Avatar
More PTV clearance from adding reliefs will open up a new world of options.
Old 09-13-2009, 04:45 PM
84BuCkeTOfStEeL's Avatar
How Do I Make A Big Cam Fit With Optimum Compression?
Maybe this will answer some of your questions. Its a pretty decent write up on fly cutting. It answered alot of mine. Hope this helps.
http://forums.corvetteforum.com/c6-t...mpression.html
Old 09-13-2009, 08:12 PM
8ByGoat's Avatar
Well then you milled way too much, the machine shop lied to you about how much they milled, or something else is off.
You know what my cam specs are and they are much, much larger than yours and I milled .0030, run the stock gasket and I am fine.
And I am trying to help You are the one telling him that if he mills the heads he can't run anything larger than the cam you run.
Old 09-13-2009, 09:28 PM
SweetS10V8's Avatar
I dont know your cam specs, I dont know any named cam specs to be honest.
I gave my experience and said.....
Old 09-14-2009, 10:28 AM
8ByGoat's Avatar
232/236 600/600 113lsa
Old 09-15-2009, 02:28 PM
Torquer V2 = 232/234 .596/.598 @112 LSa
Quick Reply: Milled L92 Heads...?
