need msd 6010 timing advice
Old Oct 2, 2009 | 06:01 PM
backdraft TD's Avatar
Default need msd 6010 timing advice
I'm running the 6010 with my 750 on the gmp intake, stock displacement ls2 with a nice cam. Msd is useless with their tech support and I was wondering which of the 6 plug ins I should start with.
thanx,
chris.
Old Oct 2, 2009 | 09:25 PM
jay_lt4's Avatar
get a laptop looked to the box and make your own table, all 6 of the pills have way too much timing for the ls engines, they all have 36* wot at higher rpm
Old Oct 3, 2009 | 06:34 PM
I agree with the timing at 6k because in my experience I think I need around 34 but don't know enough to use my laptop on the box. I'm not sure how much I can screw things up so I'm better off leaving that to a pro.
Old Oct 3, 2009 | 08:29 PM
jay_lt4's Avatar
most ls engines need only 26-28*max timing at wot
Old Oct 7, 2009 | 01:23 PM
LS1MCSS's Avatar
You will be amazed at how easy it is to plot a timing graph. You just click where you want to make a change and then drag the line there and let up on the mouse button. It will take a major effort, on your part, to screw it up.
Old Feb 13, 2010 | 10:07 AM
Since the last post 'Ive done some good road course testing including winning my class at the kit car nationals at gateway intl so thanx for the advice guys. I figured out how to get the laptop/box talking and made up a few graphs trying different timing routes but it all doesn't seem to FEEL any different (other than when I got rid of the stock program, huge difference) so I understand I need to dyno for the max benefit but I want to learn more about what timing does and how it works to be able to make up a few graphs and just load them run after run to save some time. I'm not a complete idiot when it comes to motors, just not too ...err...techy.
Any ideas on where to get schooled on making a timing graph? or can someone share theirs with an estimated hp?
thanx,
chris.
Old Feb 13, 2010 | 01:38 PM
xpndbl3's Avatar
not carbed ones. Seen 34-38 as the norm for most with cam and/or head work.
Old Feb 13, 2010 | 03:54 PM
Well, I raced this car at 36* so it does work but I followed the advice of a local company that builds race ls9'S and did the machine work on my block and his recomendation was to set it at 29* max at 6k and I have to admit after i did that the car was much less notchy and stumbly in the pits and more driveable. I did a progressive curve similar to the factory one hitting 28 * at 3k and 29* at 5.5k with the rev limit set at 6600.
But without knowing more about timing i would have to say I just winged it.
Old Feb 14, 2010 | 09:53 PM
jasonsnova's Avatar
i'd be interested too...in the process of building a lq4/l92 headed engine...i'm coming from a sbc and 36-38 was always the norm.. i'd be interested to see others timing set up.....
Old Feb 19, 2010 | 01:11 PM
Hmmm, looks like no one really knows anything about ignition curves.Interesting. Well I plan on spending about half a day on the dyno and will draw up numerous charts to program and I'll post my findings.
Old Feb 19, 2010 | 01:51 PM
jasonsnova's Avatar
i'm used to sbc's and they love timing so 28-29degrees sounds retarded to me but i also have heard ls engines dont like as much timing... i's love to see more info...even tho i'm 2 months away from running....
Old Feb 19, 2010 | 02:42 PM
xpndbl3's Avatar
Car picked up everytime I added timing from 28 above 3500 to up to 30, then up to 32, that's as far as I got at the dragstrip with a buddies car. Never got to tune on mine much since I don't own a laptop yet.
Old Feb 20, 2010 | 04:50 PM
LS1MCSS's Avatar
Here is what 36 degrees timing from the Edelbox will do if you have just a little more than stock compression. Just listen to the engine.
http://www.streetfire.net/video/Quic...ith_123863.htm
Old Feb 22, 2010 | 05:40 PM
Cool video! lol. My car drove like a scalded dog on the track at 36 but I've had some very knowledgable people tell me at 6k it has to be under 30*. I wonder if road racing would be different to drag because i could stay close to or above 6k for periods of time instead of shifting.
Old Apr 12, 2010 | 04:48 PM
team39763's Avatar
Any updates? I was running my timing at 28*, but just a few weeks ago I changed it to 32* and it seemed to like it. I plan to try more timing when i get to a real track.
Old May 1, 2010 | 10:03 PM
team39763's Avatar
Anybody else got any more results with more or less timing?
