TRICKFLOWS or AFR
Old Jan 9, 2010 | 08:47 PM
NASTY98TA's Avatar
Default TRICKFLOWS or AFR
Ok everyone I am looking to build a awesome street car, something I can drive and something I can even take on long trips. With that said I have a LS2 402 that I used on my FI setup that is like new, I am going to use this motor and change the Pistons.
I am looking to get 11.5:1 compression ratio and use set of Great heads to obtain a goal of roughly 540/540 power wise give or take. My dilemma is what Heads and cam combo. Looking at AFR 205's or 215's and a good cam to obtain this goal while obtaining great street manners.
any info you guys have to share is much appreciated
Thanks
Brian
Old Jan 9, 2010 | 11:40 PM
Gregorya24's Avatar
Get some all pro lsx heads brian
Old Jan 10, 2010 | 03:41 AM
baezi z06's Avatar
if i where buying set of new heads today on my 402 build i would go whith TFS 235cc.
but you can get around 530-540/490-510 TQ i think, if you decide to use 215cc for example TFS 215cc and right combo , whith cp around 11.5:1
maby more (search for: alling_c5 ) on the forum
but i would select the heads first and then decide the cam.
You can get big Cam whith good manners.
i´m running wiesco - 8cc dish pistons and just finished milling my heads TFS 215cc 3.9" bore down to 57.5cc and then opened the chambers up for bigger bore 4" and the cc is now 59cc, that should leave me whith 11.6:1 in CP whith .6" gaskets , i was in 10.95:1
but i havent runned it again after these changes...
Cam is Txgiant cam 248.254 - 615.622 -114 it´s a bit rough but very fun street car. a good TQ on low rpms and a lot on mid range
good luck Brian
Baezi
Old Jan 10, 2010 | 01:04 PM
NASTY98TA's Avatar
good luck Brian
Baezi
Thanks, I was also looking at the TFS, the cam I was looking at was a little smaller
Old Jan 10, 2010 | 01:20 PM
NASTY98TA's Avatar
good luck Brian
Baezi
Old Jan 10, 2010 | 10:25 PM
InsaneDomestics's Avatar
TFS Are Good Heads But I Think They Are A Little Pricey. The 215's Only Flow Around 320-330 And Cost $2200+ I Would Just Get A Set Of L92's That Flow The Same 320-330. You Can Find Them On Here For $650+ All Day. Get Them Ported And You'll Have A Better Set Of Heads Than The 215's And Will Have Only Spent Half The Money
Old Jan 11, 2010 | 06:49 AM
tektrans's Avatar
WCCH makes a set of L92's, reasonably priced I think and a ported L76 intake (like mine) should be more than enough to feed a 402. Cartek did my L92 headed motor they can put a good h/c combo together for you.
I think for a good street motor that will make great low wend torque the L92's are a good choice and a stock L76 intake is reasonably priced and works well with just a 90mm tb.
Old Jan 11, 2010 | 04:46 PM
NASTY98TA's Avatar
Default trickflows vs afr
Its between afr's and trickflows
Old Jan 11, 2010 | 05:01 PM
Gordon0652's Avatar
Why??
Old Jan 11, 2010 | 05:05 PM
tektrans's Avatar
Originally Posted by Gordon0652
Why??
I apologize, I just re read the post and you did say trick flow or afr's and I'm talkin' about L92's.
Old Jan 11, 2010 | 05:08 PM
Gordon0652's Avatar
I am asking the OP why not WCCH L92s, they are an AWESOME piece for the money! I'm with you.
Old Jan 11, 2010 | 05:11 PM
Pseudonym's Avatar
I say TFS 225s, 215s are not enough for a 402 in my opinion. Good luck with the build.
Old Jan 11, 2010 | 05:46 PM
baezi z06's Avatar
i agree but go all the way ...... "tfs 235cc" and milled them. for 11.5-11.6... no question
baezi
Old Jan 11, 2010 | 05:49 PM
smok'nZ's Avatar
MASS seller approved
baezi
i dont think he wants to mill them since he is procharged
if you dont want to save money and get L92's tfs are WAY better than afr's
and on a 402 i would think 225 at least id not 235-245's
Old Jan 11, 2010 | 05:53 PM
baezi z06's Avatar
He is going NA i think....
here is a link og 402 whith TFs 235 making 570rwhp on 12.1:1CP
https://ls1tech.com/forums/dynamomet...-tfs-235s.html
good luck
Old Jan 11, 2010 | 05:54 PM
NASTY98TA's Avatar
Default torque
Just worried I am going to Sacrifice torque with top end with the bigger cc's...
Old Jan 11, 2010 | 05:59 PM
tektrans's Avatar
The guy wants what he wants. I like my L92's.
Old Jan 11, 2010 | 06:02 PM
Pseudonym's Avatar
I would still say 225s are good for a 402 in a street car. I wouldn't go with 235s until 414ci for a street car running about 11:1 cr.
You could use 215s if you really want to.
Old Jan 11, 2010 | 06:39 PM
02 z/28's Avatar
afr 225s
Old Jan 11, 2010 | 06:40 PM
NASTY98TA's Avatar
Default awesome setup
good luck
Those are great numbers, the powerband as far as torque seemed a little high in the rpm's. How is the street manners
