TRICKFLOWS or AFR
Old Jan 12, 2010 | 12:39 AM
SIC LSX's Avatar
LOL DUH Trickflows, i would even take l92 heads or ls7 over AFR's
Old Jan 12, 2010 | 01:01 AM
NASTY98TA's Avatar
Default Trickflows
I have decided, I am going to do Trick Flow 235's and have the motor setup up for 11.6:1 Compression, I am going to go with a Fast 92 intake with Nick Williams TB, We will see what happens
Old Jan 12, 2010 | 01:22 AM
baezi z06's Avatar
will be great combo there man
Baezi
Old Jan 12, 2010 | 01:39 AM
NASTY98TA's Avatar
Default combo
Baezi
Thanks
Old Jan 12, 2010 | 01:58 AM
SIC LSX's Avatar
lol sounds close my friend Tj's cars motor set 408ci 11.1 TFS 247/255 623/623 108lsa cam it put down 510whp through a th350 with unlocked 5500 stall, 9" with 4.33 and slicks! So in a m6 car would be a lot higher. He runs 6.2*'s in 1/8th mile at 109mph. street car that drives 50 miles to the track one way
https://ls1tech.com/forums/multimedi...ile-video.html
https://ls1tech.com/forums/drag-raci...s-glide-2.html
Old Jan 12, 2010 | 04:21 AM
LSWNDR's Avatar
Tektrans has got the nuts man! The L92/LS3 heads are the way to go, hollow stem valves, milled to 68cc, yella terra 1.8 rockers, and a texas giant cam from texas speed slighty modified with a few added numbers with a 114LSA then spray the **** out of it. Your for sure gonna make nothing less than 540/520 through an auto no doubt and have decent manners on a street with about a 3800 converter. Check out texas speed first they know their **** when it comes to cylinder heads i don't give a **** what anybody says! I know some badass cars in stl uncluding mine 408+ set-up's making some nasty ******* numbers before the nitrous, turbo, and supercharger.... Any factory casting head that can flow 340+cfm out of the box with some porting and a mild 624'lift cam with a stock intake making 550 to wheels has my vote any day of the week. Do you homework and quit looking at the big names that people encourage you to buy! honeslty why do that when you could spend $1500 on L92/Ls3 heads fully assembled and do the same damage. Trust me i say it's the better bang for the buck! If you think Trickflow/ AFR are the nuts when it comes to cylinder heads by all means git're done.
Old Jan 12, 2010 | 04:23 AM
LSWNDR's Avatar
It's like ******* honda and mustang owners you try over & over to convince then that they are **** slow, but they swear up an down you are retarded! lol goodluck with the choice either way you can't go wrong because a bowtie's hanging off the front of it!
Old Jan 12, 2010 | 08:16 AM
Brian Tooley Racing's Avatar
Picking a cylinder head based only on flow numbers is like getting a mail order bride based only on her hat size.
You can't compare an L92 head with a 260cc intake port volume and a 2.16" valve to a TFS 235 head with 231cc intake port volume and a 2.08" valve, it's like comparing apples to oranges.
The key is the total combination, one of our customers holds the C6 LS3 head/cam record, but those heads are still over $2000 if you need to buy castings.
It's very hard to beat the TFS cathedral port heads combined with a Fast intake, if you look at the results you will find out. The all time fastest N/A list, the fastest hyd roller cammed cars still running a Fast (not carb, solid roller) are with TFS heads. Coleman Roddy has run 9.241 @ 146.29 with TFS 245's and James (TXCAMSS) as run 9.39 @ 141 with TFS 235's.
https://ls1tech.com/forums/drag-raci...s-any-c-i.html
Also look at the dyno section and read through the results. https://ls1tech.com/forums/dynamomet...s-part-ii.html
I think the OP is headed in the right direction based on results.
Old Jan 12, 2010 | 02:18 PM
98Z28CobraKiller's Avatar
Restricted User
When my car was NA with the 408, I ran consistant 10.30's at 130 MPH with 3800# race weight. I was running just under 12:1 compression, Crane 242/252 cam on a 114 and drove to and from the track every time. I was running the same AFR225's that I am running now and the car was geared and cammed for spray. I still run the stock rockers and LS7 lifters.
Old Jan 12, 2010 | 04:16 PM
airforcemanss's Avatar
nick williams had tfs 235's on his 402 and i believe its one of the highest hp 402's there is. i think he hit 570rwhp with good tq. search under his name. one day i will have my f1a procharged l92 topped off with tfs 235's
Old Jan 12, 2010 | 04:26 PM
SIC LSX's Avatar
friends TFS out of box record car David AKA stripes owner of G.C.R.
408ci 6.0 iron block, trick flow 245 cylinder heads, solid roller cam, and a super victor intake, through a rossler th400, 6200stall converter, ford 9" with 4.56 gears it made 652whp abd run 9.30's na
vid i took/made
changed the music from rock for once
http://www.youtube.com/watch?v=IqrCP0IVWHI
and 1/8 mile in car pass
http://www.youtube.com/watch?v=HxFkH1g3q7M
more info here
https://ls1tech.com/forums/dynamomet...ad-record.html
Old Jan 12, 2010 | 04:38 PM
  #32
LSWNDR's Avatar
Yup i'm sure they made good power with those set-ups but you can spend less money on the factory casting head and make about the same power. I'd never buy a fast anything to bolt up to my car. Thats why i'm getting together all the parts together for a single plane set-up with a 4Brrl TB.
Old Jan 19, 2010 | 03:32 PM
  #33
5LTRETR97's Avatar
I would go with trick flow. I have a 11:5:1 LQ9 408 with 225cc trick flows, Fast 92mm. On the engine dyno I made 635hp and 577ftlbs. Almost done, so I don't know my rwhp or torque. Pricey, but well worth it.
Old Jan 21, 2010 | 06:02 PM
  #34
mike c.'s Avatar
I have l92 heads on a 402ci and got good results with the combo(i hope better with the ported intake and pat g cam going in). If I had to do it all over again,I would go trick flow 235 heads on a 402ci. They make the power and from what I hear drive great too. Now,I'm just waiting for trick flo or afr to make a after market ls3/l92 typ hear so I cam swap to something better. Good Luck with the build.
Old Jan 22, 2010 | 02:10 AM
  #35
Mr Monaro's Avatar
Wink
Carnt go wrong 225 TFS on 402 Fast 90 3500 stally 500rwh top head package.
CHEERS
Old Jan 22, 2010 | 12:57 PM
  #36
NASTY98TA's Avatar
Default Heads
I am really stuck between the AFR 215's and TFS 235's, I know they are really two different heads, but from what I'm gathering the TFS 235's supposedly won't sacrifice any low end torque...
Old Jan 23, 2010 | 12:10 PM
  #37
helicoil's Avatar
more info here
Nicely done car, I like all the detail in it. Looks really good. Damn, 8400RPM on the 2-3 shift! Bitchin'!! To the OP a 215 AFR and a TFS 235 are not apples to apples two totally different potentials. I would suggest the 215 AFR or TFS for a true street car, and the 235 for a more street/strip car with a power adder, especially on a 402-408. There is no doubt you can make GREAT power with 215's on 402-408 engines, been done quite a bit on this forum alone. Although not personally having done this, I am sure the SOTP driving experience would put a huge smile on your face. At the track I think the larger head would out do it slightly if convert'd and geared properly
I am doing a build with TFS225's on a 403 now, but I know I will be using a little gas down the road too. I had some TFS 215's but opted to step up. If I remember there are no differences between the 215 and 225 exhaust ports, only difference in flow is on the intake side and it is not huge.
L92's are great for the money, but IMO why stick a fair amount of money in castings that are one dimensional and limited in their uses. Head lift on these engines is an issue as we all know. What if you choose to go boosted or N20 down the road with your combination?
Old Jan 25, 2010 | 07:53 PM
  #38
quik01ss's Avatar
If I'm not mistaken nick williams vette with the tfs 235s was dyno'd on 98 octane I would like to see some 93 octane numbers he would most likely turn the timing down a bit for not running a higher octane to gain power from more timing....but I am looking at this https://ls1tech.com/forums/dynamomet...big-power.html since I already have afr 205s it will make a high velocity air speed motor for a very snappy throttle response for some fun on the street.
Old Jan 26, 2010 | 03:25 PM
  #39
slow trap's Avatar
with the right stick in there it will still have great bottom end even with a 235 head. something in the low/ mid 24x i high 24x, low 25x e on say a 113 +3 will still give you a decent dcr and perform great. some people have had good luck with the l92/ls3 heads but there have been quite a few dissapointed also. go ahead and get the new 102 mm fast with a 100mm+ tb and be done.
just my $ .02
Old Jan 26, 2010 | 05:10 PM
  #40
vetteboy2k's Avatar
Our car(03Z06 vette) also ran 9.3x's N/A with trickflow 245 heads and trapped 148 mph so far with a 6speed on a small drag radial.
The car dynos around 700rwhp n/a with a 388ci motor.
