LS ITB's
Old Jun 9, 2010 | 06:54 AM
  #81
bug man nrg's Avatar
Thumbs up Itb
This is a good looking set up .There is a lot of fab work in this kit this must come with a price tag .The welds look spot on .What is the cost on this set up
Old Jun 9, 2010 | 08:34 AM
  #82
Stang's Bane's Avatar
Originally Posted by c5blkvette
Yes similar... and you can see they have tried to make the plenums as large as possible while still packaging neatly within a confined space. I would love to see them with the covers removed from the plenums.
As already discussed, the main benefits of ITBs on a race car is the throttle response/control. The power is limited by the restrictors.
Very true. That car only makes around 580 hp. When you look at the size of the restrictors that that car breathes though, it is amazing that it makes that much..
Old Jun 9, 2010 | 03:27 PM
  #83
lstvr's Avatar
And people are saying my trumpets might be short! that does not have any!
Old Jun 9, 2010 | 06:51 PM
  #84
Just_Robert's Avatar
I spoke with a guy at Inglese today. He threw out 8 g's lol. I'm gonna check them again tomorrow and see if I can speak with a different person to confirm that.
I've also got to send in a quote request form to Hogans!
Old Jun 9, 2010 | 07:34 PM
  #85
c5blkvette's Avatar
I guess it is in the eye of the beholder....
Old Jun 10, 2010 | 07:08 AM
  #86
c5blkvette
Originally Posted by Just_Robert
A little OT, but I was interested in an Inglese setup for an L92. They said this, "We do but it is (currently) an extremely custom piece." I'm gonna give them a call tomorrow for more info.
Another alternative (Hogans lower intake/Inglese stacks)
this is a lot of work if you spend alot of time an a tig welder and all the cutting and fitting to get it right is hard work .
Mad props to the guys that made this
Old Jun 10, 2010 | 04:26 PM
  #87
ZO6 LandRocket's Avatar
c5blkvette
Fat girls need love too..............
Old Jun 10, 2010 | 06:43 PM
  #88
What is that about ?????
Old Jun 14, 2010 | 02:21 PM
  #89
I ordered the lower manifold today. Tim & Sheryl took care of me at Hogans.
Lower Manifold - $1800.
Inglese ITB's - $1900.
Fuel Rails - $300.
Air Cleaners - $500.
Old Jun 14, 2010 | 09:03 PM
  #90
Default ITBs
Fuel Rails - $300.
WOW THAT IS A PRICE TAG $4500 for a ITB set up is that shipped and installed
Old Jun 16, 2010 | 05:06 PM
  #91
vetteboy2k's Avatar
Originally Posted by LS6427
I've posted this before.
He made 65 HP more using the ITB intake over his Wilson sheet metal intake. Couldn't get the Wilson to idle less than 1,200, the ITB idles smooth at 600 rpm. Its an LSX 454ci., 13.5 E85 fuel, 650lift 260 duration @50 on a 114ls on 1.7 ratio, AFR 245cc heads.....and if you contact him, he's a member here too....thats 752 RWHP.
http://www.streetfire.net/video/GTM-...ETC_184408.htm
Nice. We're making similar numbers with a 388ci.
Old Jun 16, 2010 | 05:07 PM
  #92
vetteboy2k's Avatar
Originally Posted by ZO6 LandRocket
Any got a drive by wire version?
Yep, we run DBW, but it takes some time to setup with the stock pcm.
Old Jun 16, 2010 | 05:10 PM
  #93
vetteboy2k's Avatar
Originally Posted by Stang's Bane
That's the thing. He doesn't have experience with ITB's. He says knows people that do. He thinks they are the magic bullet that will make any motor make more power and that everybody should run them. They are rpm limited just like anything else. Will they make more power over a larger rpm range than any other intake setup? You bet. Are they great? You bet. ARe they great for everyone?? Not hardly. Will they make more power from 7k to 8k than a GOOD sheetmetal?? No.
I agree with your last statement plus the fact that packaging any kind of filtration system for a F-body/vette that won't kill power is a whole new world of problems.
JMHO
Ours didn't seem to be rpm limited although it wasn't designed to buzz to 9000rpms. Also, that's the beauty of adjustable runners albiet a tall task without an engine dyno.
Old Jun 16, 2010 | 05:13 PM
  #94
vetteboy2k's Avatar
Originally Posted by obZidian
To sum it up, is an air-box NECESSARY to run the ITB intake? That GTM, idling at 600rpms, wasn't using the air-boxes.
Also, DBW wise, I saw a kinsler on a C6 Z06 (MTI-racing mile car 206mph N/A) with what looked like a stock TB, chopped and the motor was "tapped" into the arm mechanism to articulate the TB blades.
What about filtration without an airbox? Anything thick enough to protect the motor without having to slip a few pairs of nike no-shows over the snorkels?!
As a streetcar yes, as a racecar, nah!
Anything you slip on the end of those trumpets will kill power. There's alot that goes into setting these things up and running them and if your not willing to put in the time and effort don't bother.
Old Jun 16, 2010 | 05:17 PM
  #95
vetteboy2k's Avatar
Originally Posted by miami993c297
What location do you use for the IAT Sensor?
Christian
With open trumpets the IAT sensor should be placed in the engine bay near a bellmouth which is the plenum.
Old Jun 16, 2010 | 07:28 PM
  #96
miami993c297's Avatar
Working...are you involved in Rob set-up???
Christian
Old Jun 17, 2010 | 08:09 AM
  #97
WKMCD's Avatar
Interesting..... Got this today.
Good morning Kevin-
Thank you for your interest in Harrop products,
We have developed our Hurricane manifolds for fitment of adaptor plates to suit the L76/98/92/LS3 heads as the port design is the same across these variants.
We also have developed the same adaptor plates to suit LS7 heads.
These units are available for a price of $5950.00 inc GST
The adaptor plates are priced at : $650.00 +GST each
Freight will be $100.00 for this item.
If you have any further questions regarding this unit, or any other products within our range, please don’t hesitate to contact our sales team.
Regards,
Matthew Porter | Customer Service Consultant
Harrop Engineering Australia Pty. Ltd.
96 Bell Street, Preston, Melbourne, Victoria, 3072, Australia
t: +61 3 9474 0900 | f: +61 3 9474 0999
e: Matt.Porter@harrop.com.au | w: www.harrop.com.au
Old Jun 17, 2010 | 09:47 AM
  #98
wait4me's Avatar
I have a few extra harrops in stock here, that i am not using. Ive had alot of fun with the ones we put on. They are all Electric throttle units. I think i have one 58mm and one 52mm. They do have provisions though for a cable under the cover.
That is my gtm in the vid. There are more of it running and i think dyno runs on youtube i think. We have beaten that car up from day one. The motor has definatly earned is money in fun.
The 224 afr where modified to match my Edlebrock 245s from lingenfelter. They worked pretty good before i pulled them off to run a set of ls3 style heads. I didnt gain much after the head swap. Kinda wish i would have left them on. As im only at 740 hp on the last dyno pull last month, Gained a little torque though with the ls3 style.
Tuning for the itb fly by wire was pretty easy once you figure out all the limitations on throttle openings and airflow needs.. Then you can make it smooth as silk and very easy to drive. Without changing the throttle progression tables, the cars are very hard to drive as they just want to take off!
Old Jun 17, 2010 | 10:22 AM
  #99
WKMCD's Avatar
Are you running the Harrop with the LS3 heads?
Old Jun 28, 2010 | 07:22 PM
  #100
My new L92/LQ4 intake manifold:
