434 ring gap help
Old Jul 25, 2010 | 02:45 PM
434strokergt45r's Avatar
Banned Scammer
Default 434 ring gap help
im spraying a 200 shot on top of about 15psi of boost i set my top ring at 39 and second ring at 33 is this too much or should i order a new set thanks they are total seal top ring is steel
Old Jul 25, 2010 | 02:57 PM
Whistler's Avatar
Sawzall and Welder Mod
Damn you could park a bicycle in those ring gaps!
Old Jul 25, 2010 | 03:01 PM
Whistler's Avatar
What kind of pistons are you running? If the upper ringland is standard, non-gas ported I would recommend a .025/.027
Old Jul 25, 2010 | 03:18 PM
LS1MCSS's Avatar
Total seal says minimum, .009 X bore, for over 150 shot. Second ring is .008 X bore. What is your bore?
Old Jul 25, 2010 | 04:16 PM
Banned Scammer
racetech bore is 4.155
Old Jul 25, 2010 | 04:53 PM
SSPerformance's Avatar
id call someone like LME or HKE
Old Jul 25, 2010 | 04:54 PM
AES Racing's Avatar
I wouldn't gap the 2nd ring smaller then the top ring, thats what causes ring flutter.
Old Jul 25, 2010 | 07:24 PM
barkingspud's Avatar
Good lord...Check with the ring manufacturer....
