LS1 to LS3
I was told I will need a conversion box because of the reluctor wheels being different. Where can I get one at?
I have Wilson manifold fuel rails, will they work or do I have to get new rails?
I will need a new TB, I plan to stay drive by cable.
Is there anything else I may need?
What are some good performance gains for this motor? I know I'm going to put a cam in it. My headers are 1 7/8
There is a converter in the for sale section right now for sale, if your needing one.
https://ls1tech.com/forums/parts-cla...ox-covers.html
What MAP sensor do I need? Is it the same one as the 2010 Vette since that is the intake I'm using?
Now I'm needing to get the Cam Sensor. I will be running the 2010 Corvette timing cover and need to know what sensor to get. Below is the double roller timing chain set I bought.:
JP Performance 4X ajustable double roller timing set. You need this if you want a aftermarket 3 bolt cam with 58x reluctor wheel.
I tried the sleeve and even relocating the box to the cabin of the car, to no avail. I've heard 002 did not fix it, but I have no direct knowledge of this one. I hope that is indeed the case. Good luck, the LS3 is an incredible motor.
I'm going to try the box 1st, its going to be mounted in the cab of the car.
