2" primary headers on a 416 anybody done it?
Old Jan 7, 2011 | 10:25 AM
87silverbullet's Avatar
Default 2" primary headers on a 416 anybody done it?
I had 1 3/4 on my ls1 and now I am going 416 and thinking about just skipping over 1 7/8 and just going to 2". Has anybody here done it and do you feel any bottom end loss? I am thinking about going true duals with it or a Mufflex system with a 4" in/out Magnaflo muffler. I just don't want to go with this set-up and end up with some sorry *** 60 ft times.
Old Jan 7, 2011 | 08:07 PM
fuel's Avatar
whats your hp on motor and are you running ant nitrous.
Old Jan 7, 2011 | 11:48 PM
litle88's Avatar
Going 416 as well, so I'm subscribing
Old Jan 8, 2011 | 12:13 AM
Jimmy P's Avatar
I had 2" primary headers on my 402..but that was with a F1C procharger setup making good power.
Old Jan 8, 2011 | 12:18 AM
vette0009's Avatar
yeah I'd run the 2" primary as well
Old Jan 8, 2011 | 07:16 AM
v8pwr's Avatar
If you're spinning the motor high enough they'll work well . If you're not low end torque will suffer somewhat . I'm building a 402 and have ARH 1-7/8" stepped to 2" w/ HVMC that opens up to 3.5" .
Old Jan 8, 2011 | 07:33 AM
The motor is not done yet just getting prepared with all my parts. The shortblock is being put together as we speak. I have PRC L92 heads going on the motor, the cam was spec'd by Geoff@EPS for the bottle. I will be hitting it with a 250-300 shot direct port.
So will 2" hurt any or should I go stepped 1 7/8 to 2"?
Old Jan 8, 2011 | 11:21 AM
ChucksZ06's Avatar
I think you will be fine...gives you room to grow.
Old Jan 8, 2011 | 11:28 AM
I think so too. I just don't want it to be a dog off the line on motor and it just be a nitrous junky.
Old Jan 8, 2011 | 12:21 PM
Austin Auflick's Avatar
I have 2" primaries on my 370 LS3 build. To tell you the truth the low end suprises the hell out of me. Not the slightest bit doggish.
Old Jan 8, 2011 | 02:23 PM
hivoltagedriver's Avatar
An LS3 is a 6.2L (376ci). How did you build a 370 out of it, or is it just an LS3 top end (looks like maybe that from your sig)?
My vote would be for stepped headers, but it depends on the rest of the combination.
Old Jan 8, 2011 | 03:01 PM
hivoltage: yeah it's the motor in the sig. Iron block, LS3 top end. I'm sure the 2" primaries really help on n2o. But honestly there's no sluggishness NA. I can break the tires loose, go side ways and all that hotrod ****.
Old Jan 8, 2011 | 05:03 PM
fuel's Avatar
what size is the stall. if you have a high stall will put you closer to the power band and 250 shot of n2o it will breath better.
Old Jan 8, 2011 | 07:13 PM
When I more done with the motor and get the intake and get it plumbed for the direct port I will call up and gnet a converter spec'd for my combo.
