Best Heads for ls3 427 for around 2500.
Old 02-10-2011 | 01:23 AM
Thefastguys's Avatar
Default Best Heads for ls3 427 for around 2500.
So im starting this damn thing over. Too many variables in the last one.
whats the best heads i can buy for around 2500 for a 600-650 fwhp engine.
Old 02-10-2011 | 11:04 AM
chriswtx's Avatar
trickflow 235s...JMOP
Old 02-10-2011 | 11:21 AM
TransWS6Am's Avatar
+1 or possibly the new LS7 small bores from TSP once they are released.
Old 02-10-2011 | 11:55 AM
walker94z28's Avatar
I have those on my 402, I think they are a great head. Got mine from Jon @ TSP.
Old 02-10-2011 | 12:05 PM
Tireburnin's Avatar
Advanced Induction
They have many options at or below that price point. Send them an email. You won't be disappointed when you buy from them and run the numbers.
Old 02-10-2011 | 12:24 PM
vette0009's Avatar
Go ported trickflow
Old 02-11-2011 | 01:21 AM
the ls7 small bores are reallllly realllly interesting. how did you guys find out about these?
and what would be the advantage to having these heads over aftermarket ls3 heads.
i looked on the website and i couldnt find any of these LS7 (ls3) heads anywhere.
and how much are they.
Old 02-11-2011 | 08:46 AM
formula17's Avatar
https://ls1tech.com/forums/generatio...-ls3-bore.html
The heads aren't out and only barely in the testing phase. No pricing has been released. I'd imagine the heads will be priced right with Texas Speed's other PRC heads.
Old 02-11-2011 | 12:47 PM
30th t/a's Avatar
10 Year Member20 Year Member
another vote for TFS235's
Old 02-11-2011 | 12:52 PM
Gordon0652's Avatar
Wish those heads would fit on my G8GT...
Old 02-11-2011 | 05:28 PM
LS6427's Avatar
Ported LS7 heads fully assembled......400+ cfm @ .650
Thats what I'm using, just about that price too.
Old 02-11-2011 | 05:51 PM
TransWS6Am's Avatar
That would be great if you could use them on a 4.070 bore, id be running them if that was the case. The OP is building a LS3 427 so those won't work without re sleeving the block.
Old 02-11-2011 | 05:52 PM
LS6427's Avatar
Oops.....I had 4.125 bore in my head thinking of a 427................
Old 02-11-2011 | 08:18 PM
COPO9560's Avatar
Do you have the LS3 heads that came with block originally? If so, getting these ported might get you to your goals for less cash and a more stealthy look. With 427 inches and the right cam, 600 fwhp might be within reach of stock LS3's.
Old 02-13-2011 | 03:02 PM
so whats the difference between ls3 heads ported and polished and the ls7 (style) heads ported and polished.
im not doing a heavy cam. NOT doing it.
so im going to have to get 600-650fwhp. with a mild cam.
i do NOT want this car to guzzle gas when im not on the peddle.
Old 02-13-2011 | 06:38 PM
midevil1's Avatar
Your LS3 heads would get the job done. Nice CNC port job and a mild cam. I figure I am making over 600 fwhp with mildly ported L92's on a 11.5 to 1 370. Cam is a 231/239 614 624 114+3. Drives great and pulling 18mpg in Houston traffic. Over 20 on freeway. Put down 504hp at 6500 thru 5.13 gears and 30.5 tires. It is a T56 in the JG truck. Lite weight valves and valve train will help also...
Old 02-13-2011 | 06:48 PM
TransWS6Am's Avatar
nice numbers midevil1!
Old 02-13-2011 | 07:19 PM
midevil1's Avatar
Thanks a lot... Engine has more in it. I think it's all in the combo. Engine has all the right parts in all the right places. I just don't see how you can go wrong with the production heads..???....
Old 02-13-2011 | 08:08 PM
so getting some stage 3 ls3 heads would do the job.?
those would be a crazy improvment from the ls2 heads.
what would i have to do to use ls7 heads from an ls7. could i use a fast 102 intake and all the same components or would the ls7 heads require different intakes and what no.
i do know that the ls7 is the most different ls motor.
Old 02-13-2011 | 08:38 PM
LPE 403's Avatar
Bolt them on....slap a 102 Fast on and go.
Quick Reply: Best Heads for ls3 427 for around 2500.
