Coolant Air Bleed System LS3 Heads
https://ls1tech.com/forums/drag-raci...or-system.html
jags that run (jtr) makes a fitting you can put in you radiator hose that has an npt fitting to act as an inlet if you dont want to drill/tap the tstat housing
i would look into where the trucks run those lines stock (assuming this is for the silverado).
http://s41657.storefront-solutions.c...l.aspx?ID=3289
