Need part # ASAP, not sure what to call part
![Exclamation](https://ls1tech.com/forums/images/icons/icon4.gif)
I have installed a oil pressure sensor into my LS3 at the port on the left side of the block.
I took the factory elbow like cover off [different/smaller from picture below] and drilled/tapped that cover. I tried copper rtv and aviation gasket maker. It appears that it might be leaking around the sender and the only reasons I could figure:
In light of that I wish to obtain the below part ASAP and install the oil pressure sender into that.
![](http://jhp.com.au/g8partsdirect/InteriorAccessories/hsvhsvsenderud-h.jpg)
Does anyone know the GM part number so I can order this tomorrow?
Also the bolts wouldn't hurt if anyone has the part # for those.
Thanks for any help.
- Wrong threads: I threaded for 1/8 NPT. Only other thread could be NPTF? Which I would have to special order I guess.
- Not enough matl to make enough threads. Need thicker part.
![](https://ls1tech.com/forums/attachments/generation-iv-external-engine/293930d1304504410-need-part-asap-not-sure-what-call-part-ofac.jpg)
Far Left.
97-2000 Corvette OFAC (still available) Part Number 12551587
Comes already drilled and with a metric thread M12 x 1.5
Drill out the metric thread using a 7/16" drill
Tap 1/4 pipe thread
Use a 1/4" male x 1/8" female reducing bush
Screw the 1/8" pipe threaded sender into that.
Centre
Fbody OFAC (No Longer available from GM new**) Part Number 12551595
Comes blank (not drilled and no thread)
Drill out the boss using a 21/64" drill
Tap 1/8 pipe thread
**Part superceded by 12577903
Right
GTO OFAC Part Number 12577903
Drill the centre using a 21/64" drill
Tap 1/8 pipe thread
Screw in a 90 deg 1/8 pipe male female elbow
You could also use this sandwich adapter-- it's cheap enough and has everything you need..
http://www.glowshiftdirect.com/oil-f...16-thread.aspx
![](https://ls1tech.com/forums/attachments/generation-iv-external-engine/293931d1304505339-need-part-asap-not-sure-what-call-part-oilfilteradapterdia.jpg)
LS1Tech Premium Sponsor
__________________
![](https://ls1tech.com/forums/signaturepics/sigpic110569_2.gif)
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
