UMI solid motor mount issue
Old Nov 8, 2011 | 03:42 PM
orange_roc's Avatar
Default UMI solid motor mount issue
I have a 98 formula with umi k member, and solid motor mounts. Im running texas speed 1 7/8" headers and off road y pipe. I can't get the drivers side of the y pipe to go on. It hits the floor and the trans cross member. I noticed the umi solid mounts could be bolted on one way to give more engine to k member clearance or fliped to bring it closer to the k member. UMI said there is only a 1/8" difference in offset. Has anyone had this same issue?
Old Nov 8, 2011 | 07:33 PM
orange_roc's Avatar
Anyone had problems with texas speed y pipe setups not fitting?
Old Nov 8, 2011 | 10:41 PM
Sales1@Texas-speed's Avatar
Ive installed our 1 7/8s headers and y-pipe on this exact k-member and solid motor mount combo and had no fitment issues whatsoever. You might try loosening the header bolts on the driver side header to allow you to make a minor adjustment to aim the collector slightly down so it will help ease y-pipe installation.
Old Nov 9, 2011 | 07:06 AM
UMI Performance's Avatar
The motor mounts are only designed to be installed one way since they are offset. I will need to double check which way the offset goes, most customers have been comparing them to how they took the factory mounts off and placing the solid mounts the same way.
I will get you a little more information because I don't know if the engine will bolt into the K-member if the mounts are upside down.
Old Nov 9, 2011 | 07:48 AM
UMI Sales's Avatar
Hey guys. The engineering drawing shows the 2.023" side up and the 2.302 side down.
This means you have the option of MAYBE raising the engine but as Ryan said, the bolts may not go through due to the tight hole tolerances vs bolt size.
Maybe try what Aaron suggested and loosen everything and maneuver things around to get it to go on. Then tighten.
Let me know how you make out and in the meantime we'll have our thinking caps on.
ramey
Old Nov 9, 2011 | 08:11 AM
orange_roc's Avatar
The mounts can def bolt to the block either way, as well as the k member. I appreciate the suggestions. I will try loosening the drivers header once and see if i can get the y pipe started.
Old Jul 26, 2013 | 01:21 AM
"Grabby" 2000Z28's Avatar
Angry UMI solid mounts
would of been nice to know this when I installed them ! When I put mine on it moved the drivers side over . I had to cut the driveshaft loop off as the driveshaft now hit against the loop .
There were no markings for right or left or up or down . Figured my original mounts were just worn . Now I'm wondering if I have one upside down ?
I looked at the picture on the UMI site and they still look identical top to bottom . What should I be looking for ?
Old Jul 26, 2013 | 07:57 AM
We now engrave "top" in the mounts and supply pictured instructions. In the past we assumed that customer could look at how their original mounts where offset and install them that way, that didn't work.
If you PM me an e-mail address I can forward you installation instructions.
Thank you,
Ryan
Old Jul 26, 2013 | 07:58 AM
UMI Sales's Avatar
Good morning.
Here's an example of proper installation orientation:
Old Jul 27, 2013 | 09:58 PM
Default UMI solid mounts
Ah , thank you Ryan . I've got the trans out right now so would be a good time to check .
I have your K-member also and am very happy with it !
Old Jul 28, 2013 | 12:56 PM
Glad to hear! If we can help any let me know.
Old Apr 21, 2014 | 07:01 PM
droksformula's Avatar
ramey
Hey guys bringing this back cause my cars on the lift and I'm having similar issues. I have an old set with no engravings. You say the shorter side goes on top but the picture showes the shorter side on the bottom?
Old Jul 2, 2017 | 04:23 PM
BennyB's Avatar
Yeah this, sorry to bring back an old thread. I've got some of the older mounts I believe were engraved wrong. I'm trying to get some clarification on this.
Old Jul 2, 2017 | 07:39 PM
BOLO's Avatar
Now when using this solid mounts, will it make it difficult to remove/install the transmission since it doesn't have that play as you would have with the rubber or urethane engine mount bushings? Especially when removing trans bolts to the engine.
Old Aug 30, 2017 | 07:33 PM
BennyB's Avatar
I just left them in upside down because mine were part of the batch that were labeled wrong. I didn't feel like messing with it again. I'm guessing all it does is set the engine down about a quarter of an inch...
