"UPDATE"!Well, well, WTF Happened Here!??
#42
While the plugs are out, disconnect the fuel and try cranking it over while you are at it.
But, like I said... be SURE it won't spray fuel out in the process, first. Ask how I know... try a fire at Record Inspection at the Salt Flats one time.
As reiterated here, something is definitely wrong and it makes no sense to continue until you find it. Trust me, it's better to tear down an otherwise intact engine now than assume/hope... and replace it later, and maybe not too much later.
All the best and looking forward to reading what you find..
#46
That's a good possibility, should be easy to check, install a known good starter and remove all of the spark plugs and disable the ignition and fuel supply and crank it and see if a cylinder is spitting out fuel or water? I would probably still verify all of the flex plate bolts and mounting surface is in good shape with no cracks around the flex plate.
#49
Buy yourself a borescope. They are worth their weight in gold. Still sounds like an ignition timing thing to me...usually a hydrolocked engine will go ahead and start as it pitches a rod. Does this engine even try to fire, or does the starter break before it gets to that point?
#50
After reading through this whole thread I thought to myself water has to be getting into a cylinder somehow. Condensation, rain (if stored outside) or cooling. My buddy's vette broke the block where the starter is connected due to water getting into the intake and filling a cylinder.
Sounds like you need to perform a battery of tests. Cooling system is a good start. Sounds like a nightmare. Good luck.
#51
#52
#54
All the plugs are pulled and fuel and spark have been disconnected. 4th starter was put in and the engine cranked over consistantly and for quite a while a handfull of times. All the plugs looked the same and no sign of coolant, or taste for that matter, on any of the plugs. All dry around each hole. I am totally scratching my head on this one. Starting to think something with timing or spark now too
You stated that it turns over easy by hand and with the plugs pulled. So no they should be ok.
When the car starts does it fire up instantly like a stock engine does? Mine still does. If so cam and crank sensor are ok. How about timing? Race cars retard the timing to start. Too much advance in your programing ?
I've had good luck with Powermaster starters. They have a nice billet mounting block , and are clockable etc.
#57
Well all i did was tighten my ground to chassis nut and backed the timing off on startup and the thing works like a champ now. I probably started and restarted it 50 times not to mention let it idle up to temp and tried it again!? All i can figure is the loose ground and the battery being in the back, not to mention high compession was just compounding everything. I'm crossing my fingers i got it after starter number 4
#58
