ignition problems
Old Oct 17, 2012 | 05:43 PM
camarozssclone's Avatar
Default ignition problems
I have a 95 Z 28 with an LT 1 motor I was driving and my RPM's started fluttering from 1 to 3 grand as my car started running really rough and backfiring I turn the car off and restarted it and it started find and made it home for the next day I started the car and went to leave my house and the car died and will not start it turns over fine and it has gas it is not getting any fire what could be the problem thank you for your consideration and helping me
Old Oct 19, 2012 | 12:22 AM
somebody please help if you know anything that this might be my car is not running right now and it is due to go into the paint shop I need to get this problem fixed I would really appreciate any and all help thank you very much
Old Oct 19, 2012 | 03:11 PM
Summitracing's Avatar
LS1Tech Sponsor
You may want to ask a moderator to move your topic out of Gen IV since it refers to Gen IV engines and not F-Bodies. Down in to the LT1 section of forum for a little more exposure to members that will have more experience. That being said, the OptiSpark in LT1 cars are notorious for going bad. Your car's symptoms sound like this could be the problem and Summit offers several Optispark II Distributors for a 95 Carmaro Z28. The MSD units are a good solution to prevent future failures.
__________________
800-230-3030
www.SummitRacing.com
Old Oct 21, 2012 | 01:44 PM
ramairws6's Avatar
Wow, are you a mod or a sponsor on here.....
Old Oct 23, 2012 | 03:06 PM
LS1Tech Sponsor
Originally Posted by ramairws6
Wow, are you a mod or a sponser on here.....
We only mentioned the first part of that post so the LT-1 members would see his post and did not mean it in a scolding tone. That being said were you able to diagnose the ignition problem Camarozssclone?
__________________
800-230-3030
Old Oct 27, 2012 | 02:30 AM
Default no fire
I did not take it in a bad tone I appreciate any help you guys offer me no I have not got the problem fixed yet I did pull the coral and have the coil tested in the coil is good my car is turning over fine and it has feel pressure it just is not getting spark I was told by someone else that may be the office park as well I just hated getting into that because you have to pull the water pump but I guess I'm going to have to do it I say this car and rebuilt it from a wreck the guy I purchased it from use to put it in a lot of car shows as well as go to the hot rod Power course it's been in several I have the car completely redone and ready for paint all I have to fix this problem now so thanks for ur input!
Old Nov 3, 2012 | 04:19 PM
Talking just an update
I want to thank everyone for all of your help I really appreciate it the issue on my car was the Icm shbox.com had great info on testing as well thanks again now I can put my sunset orange paint on yesssss!
Old Nov 8, 2012 | 03:27 PM
LS1Tech Sponsor
Glad to hear you got it figured out.
__________________
800-230-3030
