LQ9 Build ideas
Looking to build up an LQ9 and swap that into my camaro.
Right now i am thinking of making a 402 stroker from a small overbore or hone 0.005 combined with 4" crank.
This is slightly a budget build, i only want to spend roughly 1500.00 dollars on everything (excluding the block and accessories)
Thoughts?
Just a basic 402 rotating assembly is going to cost more than that. Then you have balancing, machine work, assembly. I would bet you're going to spend in the 3-4000 dollar range when all said and done.
Im still debating how i want to do this. Money isnt really the issue with this build its the time table i have. I only have about 14 months before i move, so i need to have this atleast sitting in the car.
14 months is a long time, there are plenty of vendors out there that have 402s already built and ready to go, or can do them in about 2 weeks.
how much is an already built one?
I have a blown lq9 (complete bottom end/block is trashed). the plan is to buy another lq9 block for ~500, then buy a forged 408 rotating assemble for ~2,000, then get PRC stage 3 ls6 heads ~2,000, and a custom cam ~400. I have a FAST 92/92 setup already and some parts i plan to sell to help offset the cost ie ported 5.3 heads and miscellaneous parts. Looking to make 500whp
**update also looking into LS3 top end now
