2005 6.0 (ls2?)
Old Sep 27, 2013 | 03:52 PM
2005LLY's Avatar
Default 2005 6.0 (ls2?)
So I have a 2005 6.0 vortec out of a 3/4 ton avalanche, in my 1972 c10. Bought the truck set up this way, has a FAST billet fuel rails, and fuel system. Has 4" cold air intake, and full exhaust system, with a tune for 91 octane. Anyways, I want more power I want to know what the best head and cam combo for a street driven truck? I want 450-500hp at the wheels. I was thinking a ported FAST 102mm intake manifold and throttle body, or I've read a ported ls6 is also a good option? Where can I buy these parts and who could tune the truck? I will add probably 100 hp shot of nitrous later down the road. Will the bottom end hold this power?
Thanks, Dylan
Old Sep 27, 2013 | 11:09 PM
omc8's Avatar
Thanks, Dylan
Well , you may not have a 6.0 they where not in a Avalanche. And LS2 was passenger car only. What casting # are your heads ?
Old Sep 27, 2013 | 11:16 PM
2005LLY's Avatar
I thought it was a lq9, but was told it was a ls2, but I will check the casting numbers. It was a 3/4 avalanche or suburban. I'm not sure which.
Old Sep 27, 2013 | 11:26 PM
omc8's Avatar
what is the casting # on the heads ?
Old Sep 27, 2013 | 11:34 PM
2005LLY's Avatar
I don't have the truck right now, where at on the heads is the casting number?
Old Sep 28, 2013 | 06:59 AM
the gas man's Avatar
I have a 6.0l or alum. ls2 from 2006 TBSS. As per GM it was a left over 2005 24x engine.
Old Sep 28, 2013 | 09:15 PM
omc8's Avatar
All 2005 LS2 are 24x 2006 TBSS, GTO, and SSR were 24x 2006 Corvette was 58x
Old Sep 29, 2013 | 01:01 PM
Anthony Phillips's Avatar
Head casting # is on front os heads by fontmost header bolt hole ls2 will say 243 on it
Old Sep 29, 2013 | 08:49 PM
2005LLY's Avatar
Thanks for the info everyone! I did find out that its the aeromotive fuel rails and fuel system, not FAST. And the motor is out of a 2005 Avalanche. So that means its got a 5.3 correct? I will be able to check the numbers on the heads Friday since that's when I will be with the truck.
I was just told by the previous owner who had a shop do the conversion that it has a Camaro ecu and throttle body if that helps figure out what motor is it in. He claims it is a 6.0 with a throttle cable instead of electronic throttle body.
Old Sep 30, 2013 | 08:39 PM
omc8's Avatar
Lower right corner of the head, so on the passenger side it will be at the front of the motor.
Old Sep 30, 2013 | 11:22 PM
SS409's Avatar
As Per Mitchell, 2005 Avalanche came with 4 engine options. 4.8, 5.3, 6.0, 8.1.
Here is some info where to find and decode the engine ID
https://ls1tech.com/forums/attachmen...entid=419713&s
https://ls1tech.com/forums/attachmen...1&d=1380601268
Attached Thumbnails 2005 6.0 (ls2?)-bkock-id.jpg   2005 6.0 (ls2?)-bkock-idtext.jpg
Old Oct 1, 2013 | 01:24 AM
omc8's Avatar
The 6.0 was available in 2007 but not in 2005. Please show where Mitchell says different.
Old Oct 4, 2013 | 08:12 PM
SS409's Avatar
Here you go:
https://ls1tech.com/forums/attachmen...1&d=1380935444
It says it did, but you are right omc8, only 5.3 & 8.1 where available on the 2002-2006 models, and 5.3 & 6.0 on the 2007+ models.
Old Oct 5, 2013 | 02:56 PM
2005LLY's Avatar
It has 317 casted on the heads, and it also has black plastic intake manifold if that helps
Old Oct 5, 2013 | 07:34 PM
SS409's Avatar
317's are Aluminum Heads that came on the LQ4 and LQ9 6.0L
I don't think that motor came out of a avalanche
Old Oct 6, 2013 | 10:27 AM
2005LLY's Avatar
I don't think so either, anything else I can read off the motor to find out what exactly it came out of? If it has a black plastic intake does that mean I have a ls6 intake?
Old Oct 6, 2013 | 11:27 PM
2005LLY's Avatar
I'm thinking a TSP cam package, 228r 112lsa, with a dyno tune from MC racing in Overland Park, Kansas.. What do you all think? Can I reach 400whp at least? I've got the full aeromotive fuel system, electric fan, long tubes, no cats, Camaro throttle body, and what looks like a ls6 intake manifold, will be a 91 octane tune.
Old Oct 7, 2013 | 02:41 AM
SS409's Avatar
Check casting number on back of block: tell me what you find
https://ls1tech.com/forums/attachmen...1&d=1381131584
Attached Thumbnails 2005 6.0 (ls2?)-ccrp_0805_34_z-1964_chevy_el_camino_engine_swap-gm_engine_block_number.jpg
Old Oct 7, 2013 | 09:59 AM
2005LLY's Avatar
Can I do it with a mirror and light? Or will I need to remove something to see it?
Old Oct 7, 2013 | 12:12 PM
99wssixm6's Avatar
What intake is on it right now is irrevelant to what engine it is. Just about all of the ls stuff from 4.8, 5.3, 5.7 and 6.0 l stuff with swap to each other. So you can have a ls1 or ls6 intake on a 4.8, 5.3 or 6.0. The best way is to post some pics and do some research on your own. the 317 head number is a great start and would make all of us think you have a 6.0l but that doesnt mean someone put those heads on a different block.
