Help with LS2 (GTO) connections
In these first 3 photos, there are 4 connectors that are all part of one big leg of the wiring harness. They lead to a big round rubber thing that I think is a firewall gasket, and so I'm thinking they should be routed inside and probably connected to the computer. However, it's hard to imagine the computer needin 4 separate connectors...
This next connector is on the driver's side near the power steering pump...
And here's a few shots of a weird little guy that I can't tell if it's electrical, fluid, or air related.
The connector above is at the end of about an 18 inch hard plastic line, and it leads back to a funky looking apparatus that's wired into the harness on the passenger side...
This thing is plumbed into a hard line that is connected to the passenger head...
On the back side of the intake, there are a couple of hoses that I can't find a place for, and that I don't know what they do. This first one comes out of the intake on the passenger side, but stretches across to the driver's side. It is threaded on the end...
Last, this one seems like a vacuum connector of some sort, but I don't know where it's supposed to plug in. It's on the passenger side...
I snapped these photos just before installing the intake.
I'll look for where the cam sensor goes, and maybe post more photos with the intake in place.
That #5 and 6 pic (fitting} should attach to the front drivers side of the intake manifold. Pic is attached. When you get it mocked up, things will make more sense.
Pictures #1 and #2: 3 of 4 connectors go to computer and tranny controller.
Picture #4: purple connector is for the MAF sensor
Pictures #5 and #6: "early fuel" evaporative system. However, where does it plug in?
Picture #7: "early fuel" purge valve with broken connector on left side
Picture #9: power brake booster
Still a mystery...
Picture #2: the White connector
Picture #3: blue/green/black connector. Possibly for the brakes/ABS?
Picture #4: the pure black connector - maybe for the electric fans?
Picture #8: black hose that goes to a hard line in the passenger head
Picture #10: hose that comes out of rear of manifold. Goes to???
Here's a new one. I can't find anything that plugs into the electronic gas pedal. And if I have to buy a cable for the gas pedal, I can't figure out where it would go. Does this have anything to do with the white mystery connector from Picture #2?
I'll refer to the above photo as #11.
Also, there are three connectors on the computer board. I have wires that go to two of them, but nothing fits the third (J1). Is it possible the leftmost connector is where OBD diagnostics and handheld tuners plug in...?
BTW, I do have the computer and tranny controller - I just wasn't sure what plugged into where until I started researching, asking questions, and mocking stuff up.
Thanks for all the help. Progress is slow, but I'm moving forward.
To sapp27 - yes, please post up any pictures you can get of the engine and where all the hoses and connectors go. Let me know if we need to PM or talk offline. Double thx.
http://www.hotrodlane.cc/PDFFILES/ls...nessSquire.pdf
http://www.ls2.com/forums/showthread...ng-Information
http://www.eficonnection.com/eficonn...spx?ItemId=848
For $145 you get most of the connectors needed to make the LS2 harness into a standalone harness. The first link provides the pinout info. I'm still unsure about the fan connections and some other things.
I don't know if I'll attempt this conversion myself, or eventually pay someone. Since the cash isn't on hand this month, I have time to think about it.
