Lowest profile Intake Manifold Available
If needed, can I simply cut 2" of top of stock manifold and plastic weld top back on?
The LT1 intake looks pretty low profile; any idea if it will fit LS3?
Thanks
Here's what you can do.....go work with the engine mounts and see if you can get a couple of inches and get some fabb'ed up. This has got to be a import with a hood this low.
I guess next time I ride in a small plane
I will check and make sure it has the proper
engine in it. I would hate to have to call a wrecker when something goes wrong up
there.
If you're concerned about lowest profile. Thats about the only way I see you getting 2 inches.
I selected the ls3 because there is a marine version designed for such crank loads and torque (there is no transmission to ratio the load) and would only need a portion of the ls3's rated hp which should allow greater life .
I would've thought that a custom-made, low profile, short runner, sheet metal manifold would've done the trick.....
KW
