Intake Manifold Flow Test:LS3 vs Rick Crawford Radius Rod LS3 vs Ported LS3 FAST LSXR
#66
I used the 1/2" rod with a point ground on it to go through the front to mark the back.
Then I drilled part way through with a "through wall" drill bit. Then I drilled outside from the back with a 1/2" step drill bit.
Installed the rods and JB'd it.
#67
Did anyone ever flow test a LS3 intake manifold with porting, radius rods, and a 102mm+ throttle body? Curious if adding a larger throttle body and having the inlet port matched would be a benefit. I'm eyeing the granatelli 103mm tb right now since TSP still doesn't have their 105mm one for sale yet
Also thread resurrection.
#68
#69
#70
depending on your h.p., cubic inches, transmission type. Weight of the car, etc. You can hurt the low end torque if you go too big of a t.b. I stayed with a 92mm on my 408 LS3 with CNC ported heads. I did pick up .24 in The quarter mile switching from my Rod mod with the stands removed ls3 intake to a F.A.S.T. 102mm with hp runners
The engine is a bolt on LS3 in a fatgen. Stock cam so nothing crazy. Just looking to mess with stuff lol but if this might hurt things then I'll skip it and stay with a ported TB
#71
That's what I'm worried about. I'm wondering if the stock TB is "small" at 90mm to help increase air velocity into the manifold
#72
So I had HioSSilver port my rodmod intake manifold to accept a NW102 and it feels like it gained a little bit in the midrange. Very happy with it and it was easy to adjust the tune for the larger throttle body. I do have clamps on the intake hose lol
#74
That’s dope! I’ve seen many people say it can’t be done.
Is that the Texas speed 102, or the eBay one?
How do you like it?
I’ve had a GPI rod mod intake for a good while but it was before they offered the porting. I never felt like it did a lot. The porting has always been on my mind and now you added the 102 to the mix haha
How do you like it?
#75
I really need to get it on a dyno to see what it makes. Never had it on one before and now I’m very curious. Per my HPT logs I think it’s flowing more air at peak torque (4-5 g/s more) and it seems to get to peak airflow (350 g/s-ish) sooner which makes sense to me. Engine can’t utilize more airflow at peak HP (stock cam) but it looks like it wanted more at peak TQ
How do you like it?
How do you like it?
The porting seems to really make a difference. I think GPI tested a rod mod vs a ported rod mod and the ported one came out on top. When logging with HPTuners it looks like around peak torque it’s moving 4-5 g/s more air now with the 102 (vs 90 Tb) and the Engine Torque PID says it gained 8-10 ft lbs at peak torque but I don’t really believe it’s that much of a gain lol
#76
Normal guy Ls3 porting and testing. 7500+ Capability
https://www.yellowbullet.com/threads...ntake.2584115/
#77
#79
The rod-mod is a good modification but I don’t know if people have gotten more performance by cutting the runners back. I know two guys did it on Camaro5 and one said there were no gains on his SBE set up and the other I think mentioned gains but I don’t remember what they were
In for the results!
In for the results!
#80
In for the results!
In for the results!
my buddy Suicidal's post :
guess ill show my ls3 intake i did..i opened it up to a 102mm tb size vs stock 90mm..i then cut the runners back from 9.5" to 7.5" in hope to get it to carry power better,smoothed an radiused all port entrys.
intern it was worth 15hp over a stocker from 6600-7000..it seemed like it flat lined an held though an dropped rapidly after 7200..not sure why or what made it do this..im sure one of you guys with more experience would know..with a holley split single plane intake an elbow combo.the test engine peaked 6900 an made 600hp.
dyno results for ported ls3
stock ls3 intake did 570hp @ 6600
Tony laino
/threads/carb-and-intake-show-and-tell.214422/post-72640714
