Valve cover pcv needed?
Old Nov 15, 2017 | 01:06 PM
SlmLrd's Avatar
Default Valve cover pcv needed?
hi guys,
i have a 2005 Tahoe 5.3 motor in my 1940 Mercury. I removed the stock valve covers and added vintage style valve covers and relocated my coils. I’m getting lean codes from both banks and checked the intake and brake booster vacuum for leaks, none. I also checked my header and flanges
for leaks and I’m sealed there as well.
The one thing im sure of is the seal from my valve cover breathers isn’t tight. Can I plug the intake vacuum lines and just vent the breathers to air, or are they needed for the system? CAI is installed, but used this photo for ease of view.
Thank you!
Old Nov 15, 2017 | 01:13 PM
Are running MAF or SD? If MAF, then the makeup air for the PCV system has to be measured by the MAF. If there are ANY leaks in between the MAF and the intake, the engine will run lean.
Old Nov 15, 2017 | 01:18 PM
SlmLrd's Avatar
im running a MAF and am pretty sure my seals are good, but will triple check. So I definitely need my valve cover breathers going into the intake for the system to work properly?
Old Nov 15, 2017 | 01:32 PM
BudRacing's Avatar
No, your valve cover breathers should be independent and not connected to the intake. You will need to effectively delete the PCV system if you are running valve cover breathers. Plug all former ports associated with the PCV.
If you run breathers on the valve covers AND have the PCV connected to the intake's PCV port, you are sucking unmetered air through those valve cover breathers.
Breathers themselves are not as effective at removing contaminants and water from the oil as a modern PCV system, but they will relieve pressure from the crankcase which is the bare minimum function needed. Seeing as this is a show/novelty car, that shouldn't be a significant issue.
Old Nov 15, 2017 | 01:45 PM
SlmLrd's Avatar
totally makes sense. I’ll block the intake ports from my valve cover breathers and see if the code persists. Thank you
Old Nov 15, 2017 | 02:52 PM
dw456post's Avatar
Or just use a valve cover breather with a check ball and hook up the pcv.
dw456post's Avatar
Where did you get those valve covers to fit an LS ?
Old Nov 15, 2017 | 03:15 PM
SlmLrd's Avatar
one side is a breather, other side has a check valve. Both are loose at the valve cover grommets.
Old Nov 15, 2017 | 03:18 PM
SlmLrd's Avatar
theyre just finned SBC valve covers with an LS to SBC adapter. Readily available. There are 2 different styles, so be sure of your application. You will have to relocate your coils, these do not fit over the existing coil mounts.
Old Nov 15, 2017 | 03:26 PM
SlmLrd's Avatar
Blocked off both PCV ports and drove around for a bit. Still getting lean codes, will check the rest of the system
Old Nov 15, 2017 | 04:56 PM
BudRacing's Avatar
Did you reset the computer before the drive?
Old Nov 15, 2017 | 07:33 PM
SlmLrd's Avatar
ummm... I believe so
Old Nov 16, 2017 | 03:37 PM
dreadpirateroberts's Avatar
Just remember any air that goes in the engine needs to be seen by the MAF. If air is getting sucked into the crankcase and then drawn into the intake manifold via the PCV routing, it has to be seen by the MAF sensor. If it's a vacuum leak, then it's unmetered.
The PCV needs a fresh air source to work, preferably from the intake tract AFTER the MAF.
You could use a scanner to check your feul trims. If they are very high at low rpm but are closer to zero at higher rpm/higher engine load, it is a vacuum leak or perhaps unmetered air from the PCV.
Old Nov 16, 2017 | 06:30 PM
dw456post's Avatar
Thanks, found them. I have been looking for these for months. I was searching for covers to fit ls and not adapters.
Old Nov 17, 2017 | 01:10 AM
SlmLrd's Avatar
here are my fuel trim numbers. They do not seem very high at idle and don’t get lower at 2500 rpms or so, but I’m still getting lean codes. Do these numbers say anything out of the ordinary?
Old Nov 17, 2017 | 01:14 AM
SlmLrd's Avatar
On startup, my fuel trim numbers are like 5.5 and get up to 11 or so when at operating temp 190-195, but when cold or hot, they don’t lower with rpms.
Old Nov 17, 2017 | 10:53 AM
dw456post's Avatar
Was it running ok before the valve cover swap? If this is the first startup and drive around, it may be that moving the location of the MAF and size of the tube requires a retune. It looks like that is a hand held programmer or scanner? The STFT's are not that bad, but you need to reset fuel trims to reset the LTFT's. Long term fuel trims are an accumulated number that the computer averages over time. Short term trims are what's happening right now. I have my LTFT's turned off in my tune. A wideband would help tell you what is going on with the fuel/air. What computer are you running? Are the rear O2's turned off and is Cat over temp disabled if you have no rear cats? That can throw off trims also.
Old Nov 17, 2017 | 11:34 AM
SlmLrd's Avatar
Thank you. I’m running the stock 05 Tahoe computer, rear 02’s are turned off. Not sure of cat over temp is disabled. This IS the first drive since motor install and I haven’t yet done a decent freeway run to let her learn at 65 for any real amount of time.
Old Nov 17, 2017 | 01:32 PM
mikedamageinc's Avatar
Nothing to add except beautiful car! Nice valve covers, do you plan to do a custom intake cover to match? The vortec cover just doesn't do it justice
Old Nov 17, 2017 | 08:58 PM
SlmLrd's Avatar
Yeah, I agree. Ended up pulling the cover but its hard to make these truck motors look as nice as the cars. Im in it for reliability and drivability for now.
Thank you!
