Crank seal leaking
Old Nov 4, 2018 | 07:15 PM
00blownWS6's Avatar
Default Crank seal leaking
A couple months ago I installed an ATI super damper and pinned it in the front along with an 8 rib crank pulley for my procharger. Everything was fine until recently. Now my crank seal is leaking behind the balancer. I’ve been reading up on this, and I guess I was supposed to loosen the timing cover bolts and install the balancer to torque, then torque the timing cover bolts? Is this how you guys have all done this? When I did my cam swap a long time ago I never kept the timing cover bolts loose to install the balancer and I never had a problem. No where in the ATI directions did it say to loosen the timing cover bolts. Or, could my blower belt be too tight and causing this leak? It’s not any tighter than I ran the 6 rib belt, which we all know is super tight. When I go to change the seal, what’s the proper method? I’m really bummed and pissed about this because it’s a lot of work with the blower in the way and I just had it all apart not long ago. thanks for any input!
Old Nov 4, 2018 | 07:47 PM
00blownWS6's Avatar
This is on a LS1, I accidentally posted this in gen 4. Anyways should be the same. Also, about the same time I did the balancer install I also installed a vented catch can between the passenger valve cover and the blower inlet hat. Could this be causing too much crankcase pressure and about to blow the front crank seal out?
Old Nov 5, 2018 | 01:14 AM
klinznilk's Avatar
I am running I have a d1x with ATI damper and zero leaks with my 8 rib set up. My balancer was installed after front cover and everything else was buttoned up.
What did you use to align the front cover? I used the seal alignment tool (Sac City Corvette). Did you change the seal out on the cover or did you reuse what was there?
Old Nov 5, 2018 | 06:29 AM
There’s no need to re-align the front cover for a balancer/damper change. The cover is already centered from the previous damper, granted you aligned it correctly. I do mine the same way you did, by installing my dampers first, and then tightening the cover, allowing the damper to align my cover/seal for me. Personally I’d be more inclined to look into this being a crankcase pressure issue, especially with boost.
Old Nov 5, 2018 | 08:53 AM
00blownWS6's Avatar
I didn’t change the seal or touch the cover when I did the balancer swap. It never leaked before so I’m pretty sure the cover was aligned properly when I did my cam swap about 12 years ago.
What would be the best way to vent crankcase pressure? I have a breather on the oil fill, and the vented catch can to catch any oil from entering the blower intake. Throttle body port blocked off. Still using the stock pcv system otherwise.
Old Nov 5, 2018 | 06:06 PM
s30.hybrid's Avatar
High crankcase pressure can definitely cause engine seals to leak. Did you happen to heat the damper hub with a torch when you installed it? Getting the hub too hot can also cause premature front seal failure.
Old Nov 5, 2018 | 06:53 PM
00blownWS6's Avatar
No I didn’t heat it. I just used a long reach harmonic balancer install tool from autozone. Then torqued it down with the old bolt and Then put the new bolt in. The install was fairly painless. It didn’t give me any problems while drawing it on.
What type of pcv setup are all you FI guys running? I’ve researched this til my eyes bled but never get a definitive answer.
Old Nov 6, 2018 | 01:50 AM
klinznilk's Avatar
I am running Mighty Mouse Wild PCV setup.
https://www.mightymousesolutions.com...en-f-body-wild (not sure if he's a sponsor)
Old Nov 6, 2018 | 05:07 AM
00blownWS6's Avatar
Do you have a diagram of how everything is routed. People swear by MM cans but never say how to hook them up and the website doesn’t have good info
Old Nov 7, 2018 | 02:12 AM
klinznilk's Avatar
This is how he advised me to run my setup. I have the PCV Wild setup can from him.
Note that on Drivers side cover I am using the tiny filter he sells in the grommet versus running a line the Superchargers Air Filter inlet.
Old Nov 7, 2018 | 08:42 AM
00blownWS6's Avatar
Does the catch can actually catch anything? It’s seems like nothing more than a breather on each valve cover. I have a breather on the oil fill port and it has never been saturated. I dont see how this system works properly but I like how clean and simple it is.
Old Nov 7, 2018 | 09:19 AM
klinznilk's Avatar
Yes mine has actually caught stuff. I had an issue early on where the oring on drain got/was damaged so it leaked/blew out on my kmember. I honestly do not know how much it is catching currently as it is stored and I only put 600 miles on it since i drained/cleaned it last.
