Dual throttle bodies?
Old Nov 6, 2018 | 11:28 AM
TexTexingworth's Avatar
Default Dual throttle bodies?
Does anyone have any experience in running twin throttle bodies? I'd like to better know what I've gotten myself into and what issues I may run into.
Old Nov 7, 2018 | 11:29 AM
jordoza's Avatar
I have run them before. Most problems i had revolved around idle and tip in or throttle response. I was running dual 75mm with ms3 but recently tuned a dual 90mm on a e38 ecm in a 2010 camaro. The extra box to run the second dbw throttlebody caused extra steps and the e38 took alot of work to make it smooth but it is possible. I hope you can tune it yourself and dont mind constant tinkering till its perfect.
Old Nov 7, 2018 | 11:31 AM
jordoza's Avatar
Niether was a true dual plenum either. Im sure that would change things also.
Old Nov 7, 2018 | 11:34 AM
What was used to link the two tb's together? A specific aftermarket controller or something else? It will be on a cross ram intake so hopefully that helps.
Old Nov 7, 2018 | 05:17 PM
sixty9fordkiller's Avatar
are you gonna use the edelbrock crossram or holley dual plenum?
Old Nov 7, 2018 | 05:27 PM
Edelbrock crossram
Old Nov 7, 2018 | 05:32 PM
someone posted this yesterday over on camaro5.com a couple of days ago for that specific crossram you're asking about
https://www.youtube.com/watch?v=fL1L...ature=youtu.be
Old Nov 7, 2018 | 05:44 PM
That's the torquerush controller. That and the Ozmo engineering controllers are the only options I know of without custom work. I have heard mixed reviews from people about the torquerush but I will likely go with it and see what happens as they have them in stock.
Old Nov 7, 2018 | 05:45 PM
i wonder it works with dual MAF sensors or done through sd tuning
Old Nov 7, 2018 | 09:59 PM
Project GatTagO's Avatar
I have dual 87mm TBs on my 67 Cougar using the Holley Dominator. Holley has a table for adjusting pedal% vs. TPS. This allows the throttle blades to open gradually for good tip in and slow driving. I would recommend using the cheaper and smaller 87mm truck throttle bodies. No reason to go huge with two of them. I use these:
https://www.rockauto.com/en/moreinfo...442883&jsn=455
Andrew
Old Nov 8, 2018 | 12:08 AM
The maf sensors were the biggest obstacle that I thought I may have to overcome. How did you go about working around this? Or does the Holley ecm account for this? I'm wanting to stick for the stock e40 ecm because it is a dd. I found two 90mm LS3 throttle bodies for only $120 shipped for both or else I would take your suggestion on the truck tb's.
Old Nov 8, 2018 | 12:25 AM
The Dominator does not use a MAF, it is speed density and uses the MAP sensor for load. I use a LS3 1 bar MAP sensor in the back of the HiRam intake. The other nice thing about the truck TBs is that the TPS assembly can be replaced for about $30 each.
Andrew
