Rocker swipe pattern, hows this look?
WHAT DO YOU THINK?
just did trick flow heads "fast as cast" 220's on an 06 LS2 corvette, saw 1000's of vid's on push rod length checking but NONE on how to do it , if you have ADJUSTABLE ROLLER ROCKERS, Soooo... TRICK FLOW says their heads are made for 7.500 PR's ,Deck is 100 thousands thicker. I'm using Crane cams roller rocker arm kit, they give you 7.250 PR's for a stock LS1,6,2,3 kit So that would mean that one would now need a 7.350 push rod, now I have an aftermarket cam that was already installed. So getting the base circle was not an option, But it is not to big of a cam So, I added.025 and went with a 7.375 long push rod and this is the swipe pattern I got after a 500 mile run
When I do wipe patterns, when it is wide and off center to the intake side, it requires more shim under the pedestal. That will narrow it and push it more to the exhaust side. Almost every roller tip I ha e done required 0.100 to 0.120 inches shim under the pedestal to get a nice narrow wipe that was very close to center.
Because your rockers are adjustable, you can shim your rockers up and then move the adjuster to compensate. But only if you have enough thread to work with.
You should be using an adjustable pushrod and checking the wipe with different lengths to see what length gives you the narrowest wipe. The rocker could be too high or too low, you don't know because either could cause excessive sweep.
Typically, it will get narrow and move slightly to the exhaust side at its narrowest. Then, with continued shimming it gets wider again. When I get it where it is narrowest and mostly centered, I run with that.
Once that is done I get pushrod length based on rocker position and preload. Use the adjustable to find zero lash / dead soft touch, take that length, add preload, there is pushrod length to order. I use calipers to measure vs counting turns. When I order I specify I measured with a caliper.
The half lift with rocker arm at a right angle method is best IMO.
Considering you can only get pushrods in .025" length increments, anyway, you could have simply removed the adjustable pushrod, altered it by .025" and reinstalled.a couple iterations of that would have indicated which increment was best.
