LS7 Wont start when hot
I just finished installing a Crate LS7 connect and cruise 4L75E transmission in my 69 convertible.
It cold starts every time and runs great when already running.However after I stop the engine she refuses to start until she sits for about 1/2 hour. Then she starts perfectly again.
For example, jump in car, run to gas station a few miles away, shut her down, fuel her up, and sit for 30 minutes to get her to start.
I have 57.9 lbs of fuel pressure, air intake temp is 120 degrees, coolant temp is 198 degrees, and she cranks over very strong and fast. Just no fire.
I've cleaned the MAF and have a fresh battery with enough cold cranking amps for C6 Z06.
I'm looking for ideas to look at next.
My only thought is to crawl under her and look for cooked wires like O2 sensor, crank position, etc.
Help anyone?
Scott
Seen fuel pumps do it a few times too.
Hook up a fuel pressure gauge and run it and shut it off. See if it builds fuel pressure right away when you hit the key. Also see if the fuel pressure drops rapidly when you shut it off or if it holds and lingers.
Have a test light handy. Run it and shut it down, hook your clip side of the test light to the battery ground or a good part of the engine that will have ground (alt bracket etc) and then pull a plug wire and crank it over while holding the tip of the test light near the coil pole, it should jump a spark out of the coil to the test light tip.
THANK YOU for the replies!
As stated she cranks just fine. I am familiar with heat soaked starters and this does not seem to be the case. She has a very strong spin when the key is turned.
I have done very little to trouble shoot since posting given the Easter Holiday and visiting family.
However, last night I fired her up, rolled her out of the garage maybe 30 feet and shut her down. Took about 5-10 minutes to unbolt the hardtop and put towels between the top and paint.
I fired her up ( no issues) , rolled her back into the garage and under the hoist for the top and shut her down. 5-10 minutes to put the harness on and lift the top straight up. Went to fire her up again to go for a drive and no fire. She turned over perfectly but no fire. She did have a smell of gas though so being flooded sounds like a possibility.. I waited another 15 minutes, she fired right up, I went for a drive, she ran GREAT, I came home and put her away.
If I remove the air cleaner and give a tiny bit of throttle next time she fails to start, maybe she'll get more air and fire up?? I do not have the ability to change the tune at this point.
IS there a recommended software package and cabling that I should get or am I better off finding a tuner in the North of Seattle area?
Again, your input is greatly appreciated!
Scott
PS: Other than the won't start after running issue the motor seems great! my car is now extremely quick to the point the happy pedal is almost a scary pedal! LOL!
But if this problem occurred out of nowhere it shouldn't be the tune that's a problem. So I would clean the throttle body (they get dirty and sometimes cause issues starting and or idling low or stalling). If that doesn't get it done try swapping the crank sensor and see what happens.
You said you just finished installing the engine. Is everything new like sensors, plugs, throttle body etc?? If so and it's always been a problem (not started out of nowhere) I would lean more towards the tune being the issue.
I've had zero issues with the motor other wise.
HOWEVER . . . . . .
The steering was also replaced with a brand new rack and pinion. The idiot who did the install, I'll not mention my name so you won't know who it was . . . reversed the power steering hoses. The rack blew her gaskets in short order spewing power steering fluid EVERYWHERE like running water. What a mess that was! Yes I have since used MAF cleaner on the sensor just incase.
I am now wondering . . . . if the engine is showing signs of being flooded after startup, is there a possibility I plugged the air cleaner up badly enough with power steering fluid causing a low volume air issue?
The bluethooth dongle and software show no codes being thrown. I trust the reader works well as I have used it on my PU with twin turbos and it reads everything there including boost.
Again, the input is greatly appreciated and do not assume I know the little things. If it is dry tonight, I'll get her out and take the air cleaner off for a quick run and see what happens.
I have a small attached garage so running the car inside is not good and it seems to rain a lot North of Seattle so I have to wait for a weather window to play.
Thanks!
Scott
tonight I had some dry weather and time to play.
long story short it seems when I shut the engine down and go for a restart the timing is advanced to 9 or 9.5 degrees. If I do not touch the throttle it will crank and not start. If I press the throttle to 15% she fires up!
on cold start the timing is 6 degrees and she fires up.
Does this make sense to the experts?
Thanks,
Scott
Since you've put the motor in, have you let it set and idle for about 10 minutes? If not do that, if it's an auto also let it idle in gear for about 10 minutes. Your issue could just be that it needs to fully idle learn.
If that doesn't work a tune adjustment should take care of it.
Help anyone?
Scott
My next thing to try is to use one of those cans of air to clean keyboards. I will use the air to try to cool the MAF since it is easy to get too. It is the only thing I can see changing while sitting and waiting. The air intake
temp. One added thing I have confirmed is to hook my timing light around the plug wires and it shows spark while cranking.
Please keep me updated as to what you do or try and I will do the same. Between us, SOMETHING will be found.
Thanks
Scott
You need to hook up equipment and or take it to a tuner to see what is really going on.
But if you want to try a few more things you can try this..
Next time it wont start pull the hose off the brake booster and don't touch the throttle and see what happens.
If that doesn't do it turn the key on for 3 seconds then off for 3 seconds then on repeating this a few times. If it cranks right up after that that will indicate that you needed to prime the fuel system first. However, if that is the case you should have the worst issues after sitting over night.
After pulling the brake booster vacuum line, there would be a vacuum leak and crappy expected idle. Is that what you want me to try?
Or, should I plug the vacuum line to avoid the expected leak?
I will not be able to do it tonight but tomorrow looks promising.
. . . . and yes, I feel like I am tossing mud at a wall . . . .
Thanks!
Scott
Thanks!
Scott
I hope to get back at it tomorrow evening for a while.
A couple of things I have to try.
First warm her up with a 15- minute drive.
Come home and let her sit turned off for about 5 minutes.
Confirm a no start situation.
pull the vacuum line off my brake booster to allow intentional vacuum leak and test for start. Make notes and come back here.
I also picked up a fuel pressure gauge and will hook it up looking for fuel pressure issues. Concern was noted the blue tooth dongle might not be accurate.
So that is my Friday after work plan. That is unless my bride comes up with more fun plans! LOL!
Again ALL input is appreciated!
Scott
PS: I did drive her last Saturday and OMG she is quick!
maybe I need a regulator in line? Could this be the issue?
Scott
