Compression ratio help!
Bore size: 4.065
stroke: 3.622
(823 heads)head chamber CC: 70cc
ls7 head gaskets: bore size 4.150 and thickness .075
Piston Style:
Dish, with two valve reliefs
Compression Height (in.):
1.326 in.
Piston Head Volume (cc):
+12.00cc
Are you sure about the .075 head gasket?? Stock thickness is .052.
But even with that it would still be a low 9.28:1.
No LS engine ever came with less than 9.5:1.
OP,
Using our calculator and your specs you would be around 8.78:1. That is really low. Going with a .040" head gasket would put you right around 9.42:1. That gets you real close to your 9.5:1 target and tightens quench up to .045". This is quite a bit better than the .080" you'd see with the .075" head gaskets you described. Tightening the quench will help provide a cleaner more efficient combustion cycle. It will also help reduce the chance of engine knock.
Here's what our compression calculator would look like using .040" head gaskets. We use 70cc for 823 heads per the research we've done on these L96 LS engines. We've compiled quite a bit of info on Gen III/IV engines. You can view charts for all of the Gen III/IV engines in our Identify Chevy LS Engines by VIN/RPO code article.
OP,
is it safe to run the motor at 9:5:1 na for a while before I add on the supercharger?
