Clutch Recommendations
Old Oct 18, 2025 | 02:47 PM
MattFatPanda's Avatar
Default Clutch Recommendations
Hi all, please help me decide between a McLeod 75357 Street Extreme or Spec SC663H? Is there any reason to pay ~$100 more for the Spec?
This will be fitting on to a Spec SC57A LS1/6 style flywheel which I’ve already purchased for my soon to be modded L92 and mated to an Fbody T56.
Or is there another brand of clutch that I should be considering?
Old Oct 18, 2025 | 02:52 PM
wannafbody's Avatar
For a single clutch look at the Diamond from Texas Drivetrain Performance.
Old Oct 18, 2025 | 03:11 PM
I have a Diamond stage 3 that’s been balanced. I put 40 miles on it and it didn’t like my 750hp 434, so I went RPS BC2. I sent the clutch back to TDP and It’s got a new lightweight billet steel flywheel. Been on the shelf for a few years now…hit me up if interested.
Old Oct 19, 2025 | 02:12 AM
Do the Diamond “stage” clutches fit an LS1/6 flywheel, or do you have to use their own flywheel?
Old Oct 19, 2025 | 03:12 PM
Originally Posted by IGN-1A
Hi, I invented the "Dual Friction" disk with Mike Hays
Lance
Do you mean the Centerforce dual friction? Just googled it and that’s double the price of either the Spec or the McLeod. A bit out of my price range to be honest.
Is it really twice as good?
Old Oct 19, 2025 | 04:45 PM
They come with their own billet steel flywheel.
Old Oct 20, 2025 | 06:24 PM
IGN-1A's Avatar
Default Disk Weight=Low
Disk Inertia can damage/wear out the Syncro Rings.
A high weight disk will cause SLOW SHIFTS.
Old Oct 20, 2025 | 08:00 PM
RB04Av's Avatar
^^^ This ^^^
Probably at least 90% of the total effort the synchros have to do to equalize the speed of everything, is to speed up / slow down the clutch disc. It's HEAVY, and even worse, it's YYYUUUUUUUUUJJJJJJJE. All of its weight is out 4 - 6" from the centerline, as opposed to transmission parts that are mostly within the near 1 to 1˝" or so. Meaning, EVERY OUNCE of disc weight, has around 4 TIMES AS MUCH leverage on the synchro rings, as the transmission does.
A dual-disc clutch just adds to that. At some point there's a tradeoff between the extra grip, vs the extra weight; not sure where that is in all cases, butt it's something that should be considered.
