LS7 Fuel rails, any aftermarket yet
Old May 4, 2007 | 09:53 PM
Phil99vette's Avatar
7 Second Club
Default LS7 Fuel rails, any aftermarket yet
Searched the archives and couldn't find any answers. Does anyone make billet fuel rails for the LS7?
Phil
Old May 4, 2007 | 11:13 PM
Cary@Perf-Induction's Avatar
Collections Hold
Default fuel rails
We finally have ours done, as well as our throttle body linkage adapter/spacer. I can try to post pics tonight. The spacer is machined 356 cast aluminum @91mm and is priced at $99.00(includes longer bolts and oring) The fuel rails are designed for standard LS1 style injectors and use stainless steel bracketry. They are tapped for -8 an oring. They are priced at 259.00 per set. They can be bought together ( tb spacer and fuel rails) for 309.00 as a kit and include tb o-ring and longer T/b bolts.
Last edited by Cary@Perf-Induction; May 14, 2007 at 09:03 AM. Reason: incorect info
Old May 4, 2007 | 11:30 PM
ss dave's Avatar
Phil, I believe you saw my post with the flow thru rails, Nasty Performance was also working on a set. PM me Monday for pics.
Dave
Old May 5, 2007 | 03:39 AM
Haans249's Avatar
Cary,
I remember seeing something about you guys also making a throttle cable bracket for us cable throttlebody guys running LS7 topend setup?
Thank you,
Adrian
Old May 5, 2007 | 01:23 PM
Collections Hold
Default yes
Originally Posted by Haans249
Cary,
Thank you,
Adrian
Yes, That is one of the items I stated above $99.00 in stock.
Last edited by Cary@Perf-Induction; May 14, 2007 at 09:04 AM. Reason: incorrect information
Old May 5, 2007 | 04:56 PM
Haans249's Avatar
Default Thank you
Originally Posted by cary et performance
We finally have ours done, as well as our throttle body linkage adapter/spacer. I can try to post pics tonight. The spacer is 60.00 and is machined 356 cast aluminum @91mm and is priced at $65.00 The fuel rails are designed for standard LS1 style injectors and use stainless steel bracketry. They are tapped for -8 an oring. They are priced at 259.00 per set. They can be bought together ( tb spacer and fuel rails) for 309.00 as a kit and include tb o-ring and longer T/b bolts.
Cary,
Thanks for clarifying! I was a little confused with your description. Does the bracket adapter come with longer intake bolts if they're needed? Sorry for all the questions, I'm starting to think that maybe the TB spacer and linkage adapter are actually one piece...Do you have those pictures to post?
Best Regards,
Adrian
Old May 5, 2007 | 05:12 PM
Collections Hold
Default mmmm
Cary,
Best Regards,
Adrian
Adrian,
Yes they are one piece. It is a cast aluminum 7/8 thick spacer with an arm to attach the throttle bracket to. I will post a pic Monday when I get to the shop. I have Craig do that, cause' I can never make it work.
thanks,
cary
Old May 5, 2007 | 07:30 PM
LSmonster's Avatar
Phil
Wilson has billet fuel rails for the LS1, LS7 & LS2 intakes...
Old May 6, 2007 | 10:13 AM
Stang's Bane's Avatar
Nasty Performance just mocked up his LS7 rails using my intake. I should receive them next week and I will post pics!!
Old May 6, 2007 | 08:55 PM
SS Blazer 07's Avatar
Here is a place.
http://www.professional-products.com/fuelrails.php
Old May 6, 2007 | 09:04 PM
VortechC5's Avatar
Just an FYI. According to Chad at Livernois those do not clear the firewall on a Vette.
Originally Posted by SS Blazer 07
Old May 7, 2007 | 07:22 AM
WKMCD's Avatar
I don't think any aftermarket rails will fit the drivers side on a C5 without cutting the fire wall. I had to on mine. As a matter of fact the OP didi it for me.
Old May 7, 2007 | 05:19 PM
VortechC5's Avatar
I figured that was the case. It sure would be nice if someone came out with some that wouldn't require cutting the firewall on a C5.
Old Mar 23, 2008 | 01:06 PM
reboot04's Avatar
I know that this post is fairly old but I thought that I would bring it back to life rather than asking the question again.
We got our LS7 back from Katech last week and to simplify the plumbing in the '67 we are looking for a fuel rail solution that will allow us to bring the fuel in on the rear passenger side rail. Ideally we would like to continue using the 'vette regulator/return layout but can do just about anything.
What have people succussfully used?
Thanks,
Old Mar 24, 2008 | 10:06 AM
Thanks,
The Nasty rails that I have are threaded on both ends of both rails. You can bring the fuel in anywhere with them. Hope this helps...
