GTO LS2 vs. Corvette LS2
Old May 21, 2008 | 12:04 AM
FadedFD's Avatar
I'll try and figure out if the alternator will clear the hood. That is my primary concern. If all is good I can run the Vette items.
Old May 21, 2008 | 12:29 AM
HSV-GTS-300's Avatar
or if not this is the next easiest.
Originally Posted by HSV-GTS-300
If you wanted to keep your Corvette balancer and thin nosed water pump pulley.....yet have GTO style placement of accessories then there is a new option.
G8-GT L76
Old May 23, 2008 | 09:09 PM
SoonLS1Powered's Avatar
Someone that works at a GM dealer needs to get those G8 engine accessory part numbers.
Old May 25, 2008 | 03:05 AM
XLR8N's Avatar
The GTO looks almost identical to the F-body assembly hold for the steering pump, does any one have the part #s for them?
Old May 25, 2008 | 08:08 AM
GTO LS2 Front Drive Accessories.
Waterpump assembly 89017593
A/C Compressor assembly 92175482
A/C comp bracket 92066950
Steering Pump assembly 92161580
Reservoir assy 92176477
Reservoir bracket 92057323 (2005) or 92068168 (2006)
Balancer/Crank Pulley 12553118
Generator/Alternator 92211821
Mounting bracket. alt 12563327
Rear brace. alt 92059707
Main accessory drive belt 92089561 (6PK1980)
Tensioner assembly main drive belt 92111701 or 12560344
Idler pulley main belt 12563326
A/C drive belt 92056207 (4PK1090)
Tensioner assembly A/C belt 12560345
Top idler pulley A/C belt 12557335
Old May 26, 2008 | 02:57 AM
G8-GT L76 Front Drive Accessories.
Waterpump assembly (Use LS2 Corvette)
A/C Compressor assembly 92157796 or 92236235
A/C comp bracket 92252927
Steering Pump 92174214
Steering Pump Pulley 92067786
Steering Pump Bracket 92067625
Balancer/Crank Pulley (Use LS2 Corvette)
Generator/Alternator 92193199
Mounting bracket. alt 92067034
Rear brace. alt 92067126
Tensioner assembly main drive belt 12569301
Tensioner assembly A/C belt 12595289 (it already comes with 92252927)
Old May 26, 2008 | 11:01 AM
FadedFD's Avatar
Will all those parts mount to the LS2 motor? That would be a great alternative for sure. The best of both worlds.
Old May 26, 2008 | 04:45 PM
Yes, will fit LS2 and LS3.
[L76 uses an LS2 engine block]
Old May 27, 2008 | 06:02 PM
HSV-GTS-300, you are the MAN!
Old May 29, 2008 | 10:31 PM
FadedFD's Avatar
Yes he is. You've helped me big time. Thank you so much.
Old Jun 1, 2008 | 09:39 AM
RUTH'LESSDET's Avatar
can someone post the part # for that g8 valve cover ??
Old Jun 1, 2008 | 09:58 AM
  #32
You mean engine cover ?
I don't know the Part # for that.
Can help you if you wanted the 2 piece covers tho
Old Jun 6, 2008 | 05:10 PM
  #33
Grve66's Avatar
yeah post those part #'s up. I like those 6.0 covers..
also that Alt part # on the L76 comes up on the GMPD website as a 1/4 panel. I would like to go with this set up but cant find the Alternator price.
Old Jun 7, 2008 | 09:18 PM
  #34
I'll have to do some digging on Monday wrt that alternator assembly part number. The drawing I have shows 3 parts to the assembly......the alt body + a long slim pulley (I read somewhere it has a clutch in it) + an end cap hollow washer looking thing for the pulley.
The assembly part number I had is hand written (scribbled) so I'll check it out.
Those 2 piece engine covers above.
I'll send you a PM.
Old Jun 8, 2008 | 09:21 PM
  #35
I just phoned a GM parts supplier here in Oz.
Part No 92193199 is good for the Alternator Assembly.
= US$300 if I bought one here today.
Old Jul 15, 2008 | 07:03 PM
  #36
Default Got Em.
Thanks to HSV's part numbers I got the alternator brackets for the L76 at my local GM dealer(for cost since I kinda work for them :p ).
The rear brace was on backorder but it arrived a few days after the front bracket. I have yet to put them on my engine, I want to see if I can get them to work with the alternator I have from a LS2 trailblazer, or if I will have to go ahead and order a L76 alternator, which isn't that cheap.
I'll post up if it works soon.
Old Jul 20, 2008 | 10:13 PM
  #37
Louis's Avatar
I cant believe no one has mentioned the biggest difference between the 2 motors.... The crank reluctor!
58x on the C6 LS2
24x on the GT0 LS2
Same engine, different crank triggers...
Old Jul 21, 2008 | 12:21 AM
  #38
58x on the C6 LS2
24x on the GT0 LS2
Didn't think it would matter as the OP was asking about an LS2 for an RX-7, either way he'd need to buy a computer to suit the engine he bought.
the 2005 Corvette LS2 was 24x
Old Jul 23, 2008 | 02:23 AM
  #39
PaulC's Avatar
I take it you're a member on v8rx7forum.com Troux?
Old Aug 1, 2008 | 09:42 AM
  #40
grelm's Avatar
You guys are amazing! I have a 2006 GTO drivetrain which I am putting in a Miata and this is exactly what I was needing. The GTO placement works great in the Miata but I wanted the accessories closer to the block like the vette for more radiator room. This is perfect! Thanks so much for the info!
