GTO LS2 vs. Corvette LS2
Old Dec 13, 2008 | 09:11 PM
  #61
Troux's Avatar
I may have made a pretty startling discovery. I think the Corvette and GTO LS2s have differently cast blocks. I tried to fit a Vette motor mount bracket onto a GTO LS2 and it doesn't fit due to a protrusion for mounting the GTO AC compressor. The GTO motor mount bracket on the passenger side is differently designed to fit over this extruded bung, though the Vette and GTO have the same driver side motor mount bracket.
Corvette Bracket On GTO LS2:
GTO Bracket On GTO LS2:
As you can see, the place where it hits is a part of the block. In order for the Vette mount to fit, the block itself would have to not have that protrusion. The Vettes do have a different way of mounting the compressor, but I haven't been able to find any pictures of exactly how, or pictures without a compressor.
Old Dec 13, 2008 | 10:20 PM
  #62
HSV-GTS-300's Avatar
Thats not all mate.
Get a square and put it like this on the GTO bracket, then do the same for the Corvette bracket.
GTO blocks gets mounted offset in relation to car centreline (distance at the blue arrows is approx 3/4"). I suspect the sides of the GTO block where the brackets mount are not machined parallel to the crankshaft centreline.
Pic of a Corvette LS2 block
Old Dec 14, 2008 | 02:05 AM
  #63
Troux's Avatar
Now I'm only getting more confused. All of the blocks you've posted look to have the same mounting points, except one picture.
http://i2.photobucket.com/albums/y20...3_ls2_06_z.jpg
See how it only has 2 of the three taps for bolting on the compressor? What gives?!?!?
Old Dec 14, 2008 | 09:01 PM
  #64
JUSTINSAMBERG's Avatar
Troux, You have the mount on backwards!!! Swap the left with the right. I know your using a Hinson subframe and would assume that he used the forward location on the block . Other wise the JTR headers wouldn't fit.
Old Dec 15, 2008 | 03:19 PM
  #65
Troux's Avatar
Actually, I think the RX7 subframes (yours and Hinsons) put the mounting brackets on the opposite sides from their stock locations, which would mean technically, you (and now I, after guessing the same thing the other night) have them on backwards. I hope I'm right on this, otherwise I'm even more lost.
Edit: I made sure, the RX7 guys are indeed backwards. Anyways, still seems odd that there would be two different castings for the LS2 block.
Old Dec 15, 2008 | 10:26 PM
  #66
You are right. They would be backwards for a vette or gto, and your swap requires them to go the other way, which takes care of your clearance issue.
With that being said, you should be able to install the motor with out any other issues.
Old Mar 22, 2010 | 11:21 AM
  #67
FreedS4's Avatar
Sorry for the thread revival, but I've got a quick question about accessory set-ups. I've got a 98 LS1 and I need to run the shorter water pump pulley for radiator clearance on my swap. If I run the LS2 or LS7 water pump with the shorter pulley, what accessory drive pulleys can I retain/what other LS2/LS7/L76 pulleys do I need to run? Thanks in advance.
Old Mar 22, 2010 | 12:46 PM
  #68
FreedS4's Avatar
Is there a water pump that has a different pulley on it that'll allow me to use all of my accessory drive pulleys, but has a shorter pulley to give me greater clearance?
Old Mar 23, 2010 | 03:04 PM
  #69
Bob H's Avatar
Hey,
I'm in Corpus - and have some parts that you can look at to see how they work.
Bottom line - with the LS2 water pump,(not the LS3), its close, but you can run the Camaro/GTO setups - its close to the edge of the pulley. Check out v8rx7forum.com for some guys who ran those setups. I have a LS2 water pump, but I'm running the Corvette/ G8 accy. Mine is going into a 94 RX7,(motor is a LS2).
-Bob
Old Mar 23, 2010 | 09:01 PM
  #70
FreedS4's Avatar
Originally Posted by Bob H
Hey,
-Bob
My best friend back home just dropped an LS1 into my old 87 TurboII. I'm swapping mine into an 89 BMW 325i. I actually just got an LS7 water pump so I'll have clearance for my radiator, with the understanding that I'll be changing out my other pulleys. How far along on your swap are you?
Old Mar 23, 2010 | 10:18 PM
  #71
Bob H's Avatar
I expect to have it fully finished in the next month,(end of April/early may). Engine is assembled, working on the interior of the RX-7 right now - finalizing a few things.
I have a LS2 water pump if you want to test fit to see how it works - might keep you from changing out all the accessories,(which means $$$$).
Old Mar 24, 2010 | 11:07 PM
  #72
FreedS4's Avatar
If nothing else, I'd like to see your build.
Old Mar 25, 2010 | 12:18 AM
  #73
Bob H's Avatar
Shoot me a PM - I'll be doing some traveling in April - but the first week is good.
Old Mar 28, 2010 | 09:26 PM
  #74
Wiot's Avatar
I have an '06 GTO LS2, and I suppose this question is academic as I'll know the answer shortly when my already ordered Corvette LS2 accessory kit gets here tomorrow, but anybody know if the Corvette accessories will work still using the stock GTO water pump & pulley? Will the belt line up properly? It looks like they're the same with the only exception being the longer pulley on the GTO LS2. From the pic's I've seen my eyeball says the diameter is the same... ?
Old Mar 28, 2010 | 09:52 PM
  #75
Nope the belts will not line up.
The GTO crank pulley puts both belts 3/4" out further than a Corvette crank pulley would.
Run all GTO pulleys & accessories or all Corvette pulleys and accessories.
1=Corvette, 2=GTO/Fbody, 3=Truck
See how the webs inside the GTO crank pulley splay outwards
The Corvette crank pulley has vertical webs.
Old Mar 28, 2010 | 11:07 PM
  #76
Wiot's Avatar
Thanks for the info, even if it wasn't exactly what I wanted to hear. The water pumps themselves are the same though, correct? The only difference is the pulley? This is where you have to say yes or I go insane...
Old Mar 28, 2010 | 11:44 PM
  #77
The GTO waterpump shaft is longer and the domed black pulley extends further forward than Corvette.
You could probably get away with running a Corvette crank balancer with a GTO waterpump...the GTO WP pulley should be wide enough to allow the belt to run 3/4" in closer to your block than its designed for.
{You cannot get away with the other way around, Corvette WP and GTO crank balancer wont work}
Old Mar 28, 2010 | 11:48 PM
  #78
Bob H's Avatar
If you are referring to the pictures above - i.e. the LS1 style pump and the LS2 style pump - yes, fundamentally they are the same except the pulley. Supposedly the LS2 and more so on the LS3 the impeller/bearings were improved. But you can run the LS2 pump pictured above on an LS1 F-body/GTO accessory engine.
Old Mar 31, 2010 | 11:03 PM
  #79
Wiot's Avatar
Thanks, that's exactly what I was getting at. I have all the corvette LS2 accessories here with me now, but the GTO motor is about 20 miles away at my friend's shop. It will be awhile until I get to where I'm mounting any accessories onto the motor, but this eases my mind a bit. One less thing I have to buy, eh.
Old Apr 2, 2010 | 02:21 PM
  #80
FreedS4's Avatar
So what I'm seeing is, if I run the LS7 water pump on my 98 LS1, I've got to run the entire LS2/LS7 accessory drive?
