400rwhp/tq from LS6/LS2
I originally posted this in the wrong forum so here goes:
What bolt ons does it take to make 400rwhp/tq corrected with stock longblock and intake through an automatic trans with an LS6/LS2 based motor in an F-body or Vette?
Thanks
Thanks
Well, there's a few important differences. The biggest being that you can get a lot bigger engine with the LS2 block by doing a 402. The LS6 can't do much.
Also, the valves are different. The LS6 valves are better than the LS2.
Very good reading. And the answer is that since it won't happen at all, buy the one that he finds the most future advantages in. So I listed them. Do you want better valves for more revs, or the potential for more cubes in the future, as well as the benefit of them right now? Thanks, I understood just fine. Me no need clarificashun, techur. LOL!
I would suggest a good set of heads and cam that is matched to the heads.
And a set of long tubes and a Fast 90 and your there. Try talking to the boys at Cartek. They make horepower with small cams and heads that are ported on site.
Bob K.
Thanks for the input guys. More than anything I was curious to see if 400rwhp/tq could be done with just bolt-ons. Since it can't, what are typical numbers of a full bolt-on LS2?
It can't -easily- be done with bolt-ons. With the LS2 you will pick up a lot with a ported FAST 90mm intake. On my GTO I picked up 15-20 rwhp with just a Magnaflow catback, no tune. I don't know about the Vettes, but the GTO's are pig rich from the factory, so there is more to gain there. Vettes also have nice aftermarket options for Over The Radiator (OTR) intakes that truly are Cold air intakes. So here is your list and I bet you can come real close to your goals:
1) Underdrive pulley
2) Ported FAST intake and ported Throttle Body with a CAI.
3) Headers -- 1 3/4" primaries will be best to meet your 400rwtq goal
4) Off road pipes, aka cat delete
5) Do your research on cat-back exhaust setups. DON'T select one based on sound clips. Select it based on dyno results. Talk to reputable speed shops and see what they recommend. Jeremy Formato recommended the Magnaflow for my GTO and I've had no regrets.
6) Light weight rims and tires. You can also check out light weight aftermarket brake rotors.
7) A good tune.
8) DO NOT mess with the torque converter. A good stall will gain you as much as half a second at the track, but you will take a big hit on the dyno.
9) Do yourself a favor and leave the car on the dyno overnight, so you have no heat soak and you have cool morning air for your pulls.
Finally, there are ways to "cheat" on the dyno. Get the smallest rim that will fit with the narrowest tire inflated to 60psi. Run a short belt (bypasses the P/S and/or A/C). Add some race gas -- the LS2 can run about 26 degrees of timing, but you pick up some knock between 5-6k and the higher octane will help that.
7) A good tune.
