Ls3 ?
Old Aug 5, 2007 | 04:50 PM
Heavy H.P.'s Avatar
Default Ls3 ?
Let me see if I got this right the LS3 or should I just say the 6.2l V8 that comes in the new Escalade that has 403hp. Is that basically the LS3? Does it have iron block or is it alluminum <- that might be spelled wrong.
Yes I tryed the search button couldnt find them.
Old Aug 5, 2007 | 05:18 PM
WizeAss's Avatar
yes... that is an LS3 engine or L92 engine with heavier valves and weaker springs on the heads, a truck style intake, and a smaller lift cam. It is the same alluminum block as the 08 vette.
Vette has a L76 or LS3 intake, better cam, better valves and springs on the heads, and a much better looking car to put all that in! LOL
Old Aug 5, 2007 | 08:40 PM
drain89's Avatar
Also:
LS3 has flat top pistons with no no valve reliefs = 10.7:1 compression.
l92 has valve reliefs = 10.5:1 comp.
LS3 has different (supposedly better) rings.
LS3 doesn't have the VVT or DOD yet. L92's do (most of them anyways).
Old Aug 5, 2007 | 10:28 PM
Heavy H.P.'s Avatar
I know the motor isnt out yet not the performance verison any way.
Would any one still have a list of the specs?
I keep hearing the motor is responding well to mods does anyone have any info on that?
Old Aug 5, 2007 | 11:44 PM
drain89's Avatar
LS3's are out. They're in the 08 Vettes.
Look in the LS3 stickies for all the info you want about it.
Old Aug 6, 2007 | 08:47 AM
Valingnor's Avatar
It makes 438hp in the new vette....which is nice.
Old Aug 6, 2007 | 09:23 AM
Heavy H.P.'s Avatar
Thanks for the help.
Now I just gotta find the LS3 stickys
Old Aug 6, 2007 | 09:52 AM
drain89's Avatar
here ya go:
https://ls1tech.com/forums/generation-iv-internal-engine/499059-ls3-l92-info.html
Old Aug 6, 2007 | 10:03 AM
Heavy H.P.'s Avatar
Alright thats more like it.
Thanks!
