How much would I gan from L92 Heads
How much would I gain from putting L92 Heads on my 05 Vette.
I have a 232,232 cam in my car with .567 lift. Its currently making 420 to the wheels.
I am looking to buy from sdpc tomorrow if the numbers are worth it.
Please let me know.
Tim
Please let me know.
Tim
You'll need to get the L76 intake for these as well. If you have a LS2 intake it will not work with these heads.
Also, will the L92 valves work with the LS2 pistons? I thought I remember from a while back hearing they were different, but could be wrong.
pistons work fine. heads will need to be milled to retain stock compression ratio and use stock head gasket. offset rocker stands will also be needed. On my 405rwhp 06 vette(cam and headers) the L92 unported heads and L76 unported intake( with a much more milder cam than previous set up) produced 450rwhp and 405ftlbs on a 91degree day on the dyno. BTW, you can't just "slap them on".....
https://ls1tech.com/forums/showthrea...5&highlight=c6
Here's what mine did by installing the PRC CNC Ported L92 heads on a ls2 car. This car had stock cam
We've seen 20hp gains cnc porting the l92 heads over the stock gm l92 heads.
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Jason
2005 Twin Turbo C6
